Old 10-25-2006, 01:18 PM   #1
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
OBD2 S14 acting crazy, help
Im trygin to help my freind fix his car. It's a 1996 S14 so its OBD2 and an automatic.
two issues:
One, when you start out from a stop and floor it, it feels like it has no power at all, or seems like it alwasys starts in 2nd gear, cause as soon as it gets up in the rpms it starts to pull like it should.
Second, the idle is crazy, it idles up and down constantly between 300-600 rpms and almost shuts off sometimes.
The car thew three codes, knock sensor, vehicle speed sensor, and intake air temp sensor
The gear on teh speed sensor is chewed up so it wasnt even turning, so the speedo is not working. Could this be why the tranny starts in 2nd maybe?
the intake air temp sensor was swapepd with a kown good one.
All the codes were reset and the CEL has not come back on, but the car sill idles super bad and it still feels like it has no power down low or it starts in 2nd gear.
What could be wrong making the car do those two things?
rim_bender is offline   Reply With Quote
Old 10-25-2006, 01:38 PM   #2
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
havent addressed the knock sensor?
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 10-25-2006, 03:03 PM   #3
rim_bender
the code never came back after we reset it, and the knock sensor has nothing to do with whats going on with the cars idle and werid power loss/or 2nd gear starts.
ia int worried about the knock sensor, just the other two problems
Old 10-25-2006, 11:19 PM   #4
projectRDM
projectRDM's Avatar
There's your problem. VSS and IAT would have no effect on idle or driveability, the VSS does nothing but send a speed signal, it can unplugged, removed, set on fire, etc. and have no bearing.
Same for the IAT, diagnositics use only. You can dip it in ice, burn it, or crush it to powder, the car doesn't care.
Knock sensor though does matter, and when the ECU reads a knock signal it will pull timing all the way out and run open loop. That would be the hesitation problem.
The idle problem is more than likely a vacuum leak, as a defective IAA would raise the idle to 1800 or so, a defective IACV would not allow it to idle period.
If the car is indeed starting in 2nd gear, adjust the inhibitor switch on the transmission and/or check for A/T codes through the diagnostic procedure outlined in the FSM.
