Old 07-13-2002, 01:54 PM   #1
fodive
fodive's Avatar
fodive is an unknown quantity at this point
After all the time i spent putting on my new exhuast...i wont be able to enjoy i until monday, because my clutch master and slave cylinder decided to not wanna work anymore <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''>
roots.
fodive is offline   Reply With Quote
Old 07-13-2002, 09:37 PM   #2
Bolo
Bolo is an unknown quantity at this point
Yup, hated when that happened to me. &nbsp;They're both pretty straight forward to replace, just make sure you adjust your clutch pedal correctly. &nbsp;Oh, while your down there you might as well remove the clutch dampener. &nbsp;It's that little box right before the slave cylinder. &nbsp;Just take the line going into the dampener and move it into the slave cylinder. &nbsp;This will give you a little more vibration in your clutch pedal, but it makes the clutch feel more direct and solid. &nbsp;I've also read that some people had trouble bleeding their clutch until they removed the dampener. &nbsp;Just thought I'd throw that out there.
Rudy
Bolo is offline   Reply With Quote
Old 07-13-2002, 10:27 PM   #3
Natty
Natty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Bolo @ July 12 2002,11:37)</td></tr><tr><td id="QUOTE">Yup, hated when that happened to me. They're both pretty straight forward to replace, just make sure you adjust your clutch pedal correctly. Oh, while your down there you might as well remove the clutch dampener. It's that little box right before the slave cylinder. Just take the line going into the dampener and move it into the slave cylinder. This will give you a little more vibration in your clutch pedal, but it makes the clutch feel more direct and solid. I've also read that some people had trouble bleeding their clutch until they removed the dampener. Just thought I'd throw that out there.
Rudy</td></tr></table><span id='postcolor'>
Yes, adjust your clutch correctly! There should be some free play in the pedal, wher eyou can push it, nothing happens, push some more, then the clutch moves.
My mechanic did not do this for me and it slowly killed by clutch in the next 4 days. It sucked so bad, I lost alot of money out of it &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
