Old 10-24-2006, 10:16 AM   #1
Jimmy Up
Zilvia.net GB Vendor
Jimmy Up's Avatar
Trader Rating: (52)
Feedback Score: 52 reviews
swapping in a fresh dash on a 89 hatch
i see clean black dashes all day long for about 100 bucks and mine is pretty cracked up. before i just jump into it and f everything up i wanted to know the details in it. is it just some brackets or is it a mini project. any help is appreciated. thanks much
Old 10-24-2006, 10:24 AM   #2
jimmytango00
jimmytango00's Avatar
jimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfection
Send a message via AIM to jimmytango00
I've never done it myself but it doesnt seem that hard. My friend took mine off in 15 minutes.... if that helps any.
jimmytango00 is offline   Reply With Quote
Old 10-24-2006, 10:24 AM   #3
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
We swapped over my buddies normal dash to a HUD and it took about 1 1/2hr.
There is 2 bolts behind were the Tach sits. First I would start by taking out the Tach and the Surrounding. After that I would drop the steering column. 2 Bolts under the steering wheel. Then, Remove the vents at the top of the dash, there are 3-4 screw's. Then Take the Glove Box out. Then remove Passenger kickpanel and one more screw is there. After that, just disconnect the passage ways for the air/heat vents and you should be able to take it out. Lemme know if you have problems. *a
'90RPS13 is offline   Reply With Quote
Old 10-24-2006, 10:48 AM   #4
g6civcx
g6civcx's Avatar
Look in the FAQ and find my tach swap thread. It will get you halfway there.
The rest is nuts and bolts. The hardest thing would be trying to get the dash vents out without damaging them.
It should take about 2 hours your first time if you're careful. I can swap mine in and out in about 5 minutes or so.
Old 10-24-2006, 11:00 AM   #5
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
thank all you guys a grip- im gonna get my hands on a dash when i get paid friday. if i have any problems im postin em. thanks again
Old 10-24-2006, 11:08 AM   #6
nissanhpower
nissanhpower is an unknown quantity at this point
yeah it sucks doing it and is a pain in the ass...drink plenty of beers prior
nissanhpower is offline   Reply With Quote
Old 10-24-2006, 11:08 AM   #7
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
Are you removing the entire dash to replace it? Then check the old threads on here. Search is your friend. Just know that what you're asking has already been addressed here. I even responded in previous threads with the same link.
But to be nice/helpful -- http://www.jdmrice.com/tech/dash/dash.html
Its step-by-step, can't get any easier than that.
Also, the dash vents "g6civcx" mentioned are long/skinny/thin ones at the top of the dash by the winshield -- 4/6 screws underneath them after popping them off, I believe. He's not talking about the ones above the HVAC controls (if you want to take those out, do it when you remove the dash, much easier to push out from the backside.)
Good Luck.
I removed mine in a few hours, and put it back in an hour --- though I did replace it with a black one. =) (Pics are in my thread somewhere around here)
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 10-24-2006, 11:42 AM   #8
Jimmy Up
Jimmy Up's Avatar
Trader Rating: (52)
that does look very helpful. thanks bro
Old 10-25-2006, 02:46 AM   #9
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
12mm
10mm
philips
beer of choice
GO for it!
Sir is offline   Reply With Quote
Old 10-25-2006, 12:51 PM   #10
projectRDM
projectRDM's Avatar
If you don't have arms. Swapping a dash is a 25 minute job, period. For a novice an hour is being generous.
