Old 07-08-2002, 10:16 PM   #1
David16
David16 is an unknown quantity at this point
I have a 95' 240 with teal interior (Dash, doors, and sides in the back) It is a nice color but I would prefer black is there any way i can buy new stuff or dye mine for cheap? Or am i goin to need to spend alot of money? I appreciate any info to the topic thanks.
<img src=http://www.steamymirror.com/dsc240sx/daves/8.jpg>
David16 is offline   Reply With Quote
Old 07-08-2002, 10:40 PM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Take out the plastic parts........wipe them down with degreaser (to get rid of Armor All buildup) , then when thats dry....wipe them with lacquer thinner...and then spray paint them with Krylon epoxy spray enamel (black spraypaint).  Make sure you dont let dust settle on the part before you paint it...and make sure you give it a couple coats (let the first coat sit overnight), then paint the next day.  With anything fabric, you could use Krylon Duplicolor black spray dye.  It will take a lot, so buy alot.  Or, you could always goto a junkyard and just pick up used black peices.  The dash will be the biggest pain in the ass....so if I were you I would buy a used dash from a junkyard, fix it up, and then just swap it with the teal as a weekend project.  Otherwise you will have to take out the teal one, spray paint it....let it dry.....spray it again, let that dry...then re install.....all in one weekend...and that sucks.
good luck
-M
400x200
mbmbmb23 is offline   Reply With Quote
Old 07-08-2002, 10:51 PM   #3
David16
geez thanks alot man, how much do you think the dash would cost?
Old 07-09-2002, 09:56 PM   #4
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
If you just want to make it black and not some exotic color, probably better gettin the parts off a wrecked car than trying to paint them.
Just check out the junkyards, might get lucky and you can strip out the whole interior. Should be real quick to get most of it out. Only time consuming parts is the dash, and thts not even really all that bad. Just gotta sarch around for all the screws and it'll pop right out.
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
Old 07-09-2002, 09:58 PM   #5
David16
that is what i hope to do but how popular are s14s do u think i will end up finding one local?
Old 07-09-2002, 10:01 PM   #6
gfisch
gfisch's Avatar
Well, I just finished parting out my '95 SE. Sold off almost all my interior pieces. It was teal though.
Maybe someone here on the board has one that they are parting out.
Could also try posting in the classified on 240sx.org
Greg Fischer
[email protected]
'97 240SX SE
Old 07-09-2002, 10:04 PM   #7
David16
I posted one here but good idea for 240sx.org thanks alot,
