Old 11-04-2006, 10:39 AM   #1
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
Can I go lower or will I need RUCAs? S14
Currently I am sitting a bit high, I didn't want to slam the car too much until I knew I could get around (it's my daily driver). I am on KTS coilovers about 1cm of preload in the front, 0 in the rear. Kazama tie rod ends and upgraded inners. SPL Parts tension rods....the rear is pretty much stock save Greg Dupree subframe spacers.
It's currently 1.5" lower in the front and .5" lower in the rear. I just swapped from 235/45's to 235/40's so I have another 1/2" of wheel gap.
I want to go down another full inch in the front and rear...that will leave me about 1" of wheel gap.
My alignment:
Front:
Camber: -2.0 deg
Caster: about +7
Toe: 0.0mm
Rear:
Camber: -1.25 deg
Caster: not sure what it ended up at
Toe: 0.5mm in
I know I am pretty close to full adjustment in the rear.
Total drop will be 2.5" up front and 1.5" rear.
Å
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 11-04-2006, 10:48 AM   #2
naed240sx
naed240sx's Avatar
naed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the roughnaed240sx is a jewel in the rough
Stock camber adjustment sucks.
Whether or not you will need rucas depends on how much camber you are ok with running.
naed240sx is offline   Reply With Quote
Old 11-04-2006, 10:55 AM   #3
alkemyst
alkemyst's Avatar
I'd like to keep it close to my current alignment specs.
Old 11-04-2006, 08:23 PM   #4
naed240sx
naed240sx's Avatar
Just look at the eccentric bolts on the rear. If they are close to the maximum settings, then you can't go any lower. If they are somewhere in the middle, then you can.
Old 11-04-2006, 09:02 PM   #5
GSXRJJordan
GSXRJJordan's Avatar
yup... the whole point of aftermarket RUCAs is to strengthen up the suspension a little, but moreso to give you more adjustment than the stock RUCA allows. Like naed240sx said, just look to see how much adjustment you have left. From experience I'd say yes, to keep decent camber, you'll need RUCAs.
Old 11-05-2006, 09:34 AM   #6
alkemyst
alkemyst's Avatar
There is a little bit more they can go...I don't know how much turning them = camber in and out though.
I will probably have to buy the RUCA's and toe rods. I here the traction rods aren't so important on the street ... it mostly just gets rid of another set of rubber bushings.
I am going to drop it today, then see how it rides at the lower ride height.
If I like it I will get them, if not I will raise it back to where it was.
Old 11-05-2006, 05:05 PM   #7
alkemyst
alkemyst's Avatar
Well I bit the bullet and lowered it today...I had to replace the rear axle hardware anyway as one of the previous owners left off the washers and castle nut on them...I have no idea why unless they swapped in a LSD and then took it out for resale. It was a factory non-VLSD car.
I measured 1" at the top of the bottom mounts and the spanner nuts...gave me 1.125" lower in the front and 0.875" in the rear.
I am down 2.625" front and 1" rear from stock. Rear has more neg. camber even with just a bit more lowering.
I am going to bring it by the shop and see if they think they can get it in my specs (about -1.5 negative in the rear) or if I will need to buy the RUCAs and toe links.
Looks a lot better though now.
Old 11-05-2006, 05:13 PM   #8
McRussellPants
I think I saw an option once where they lowered their car .9435341" and then crashed it.
I'd be careful like that, your tires will prolly wear down sometime over the next 10,000 miles. at least keep it higher than .7344353" lower than stock.
McRussellPants is offline   Reply With Quote
Old 11-05-2006, 05:20 PM   #9
TokyoNights
TokyoNights's Avatar
TokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really niceTokyoNights is just really nice
Send a message via AIM to TokyoNights
you dont need toe links
TokyoNights is offline   Reply With Quote
Old 11-05-2006, 06:39 PM   #10
alkemyst
alkemyst's Avatar
Go Duck a Sick.
Just posting my specs. Sorry if that's too much for you.
Check out my site: driftkat.com I don't have the "KAT" yet...but I do my own mods and drive it.
Old 11-05-2006, 07:25 PM   #11
Jefferson
Jefferson's Avatar
Jefferson is making a name for him/her selfJefferson is making a name for him/her self
Yeah I don't think you need toe links in the rear. My cars lowered (I guess like 3in over stock) and my alignment guy was still able to get it pretty damn close to zero. I have had it like that for over two years and no noticable tire wear (with -2.5 rear camber), so I think you should be OK.
Jefferson is offline   Reply With Quote
Old 11-05-2006, 08:00 PM   #12
alkemyst
alkemyst's Avatar
On RUCA's though right? The toe links aren't that expensive when you are dropping coin on RUCA's for a S14 (S13's are so much cheaper)...
Kuah at SPL Parts told me to skip the traction arms, but I would probably need both the RUCA's and Toe links for my lowering.
Old 11-05-2006, 08:30 PM   #13
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Originally Posted by alkemyst
Go Duck a Sick.
You do your own mods AND drive your car?
holy crap
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 11-05-2006, 08:36 PM   #14
McRussellPants
Hes got one hell of a list of 25% of the catbacks and coilovers for S-chassi too.
Old 11-05-2006, 09:47 PM   #15
Jefferson
Jefferson's Avatar
Yeah I'm on RUCA's, but the point I am getting at is I was able to get the alignment pretty damn close to zero toe without the toe arms. The way I think of it is if I can get away with decent toe setting without having to spend money on toe links, I use that money for something else.
If you want to buy the toe links go for it. But with that conservative of a drop (1.5 R)you might be able to get away with stock rear links, If I make any sense
Old 11-05-2006, 09:49 PM   #16
alkemyst
alkemyst's Avatar
cool...I wasn't sure either.
RUCA's are still the biggest expense (unless I was also doing adj LCA's).
thanks
Old 11-05-2006, 09:56 PM   #17
alkemyst
alkemyst's Avatar
It's not my major pasttime...this was a list from about 2004 though. My past time is driving and doing stuff to me car and others (my dad has a 408ci 1996 Bronco I mess with along with some other people's cars that need work...fvck I bought the tools may as well use them).
No updates save one on the Nismo Type R G attacks someone emailed me and that the lower lips on S14 Zenkis weren't body color from the factory.
If anyone has the other 75% of cat backs and coilovers out there feel free to send me even a link with the specs and I will update my site.
Old 11-05-2006, 10:44 PM   #18
chmercer
chmercer's Avatar
11:43:39 PM: 1cm of preload
11:43:44 PM: kazama tie rod ends.
11:43:52 PM: .83252352 cm lwer than stock
11:43:56 PM: Greg Dupree Subframe Spacers.
11:44:01 PM: GDSS
11:44:09 PM: DTGDSS.
11:44:14 PM: one letter off of DTSS
11:44:24 PM: GT-DGSS.
chmercer is offline   Reply With Quote
Old 11-06-2006, 01:05 PM   #19
alkemyst
alkemyst's Avatar
snip
huh? WTF is that?
