Old 11-06-2006, 12:23 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
vlsd question
i have the j30 vlsd with my s13 diff cover on it. and i install everything correctly but it clunks every time i shift gears. i'm just wondering will i need the abs driveshaft so it wont clunk no more.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 11-06-2006, 12:37 PM   #2
orion::S14
orion::S14's Avatar
What did you do about the front diff mounts - - >
Did you use longer bolts???
Do you have the J30 bushings???
If it's loose up front, it can clunk...and someday soon, it will fall and crack your subframe.
If you addressed those items...then look elsewhere.
- Brian
www.KA24DEvelopment.com
Old 11-06-2006, 11:18 PM   #3
s13silvia123
- Brian
i used longer bolts but it still clunks.
Old 11-06-2006, 11:25 PM   #4
s13silvia123
- Brian
i used longer bolts but it still clunks. the bolts were 80mm long
