Old 08-26-2006, 06:54 PM   #1
bigteddyted
bigteddyted's Avatar
bigteddyted can only hope to improve
tranny swap question
i have a s13 tranny and im tryin to put it intoi my s14. Would that work corectly. Both motors are 16V but the tranny is and obd1 and my car is an obd2.
bigteddyted is offline   Reply With Quote
Old 08-26-2006, 07:00 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
it'll work as far as i know... i dont see why it wouldnt
Slip Gypsies Blog
not sure if you realize this
Old 08-27-2006, 08:23 PM   #3
bigteddyted
Thank you.
any one else ever heard of this or thinks they might know something.
Old 08-28-2006, 09:18 AM   #4
projectRDM
projectRDM's Avatar
I find it amazing people still ask this remedial, beaten to death shit. I know I've typed it at least three hundred times before, but here it is again for the lazy people.
ALL 89-98 240SX TRANSMISSIONS ARE THE SAME
Only a few sensors differ throughout the entire production run.Nothing else. You could have even looked at them both and figured that out.
Old 08-28-2006, 10:14 AM   #5
dopeassjackson
dopeassjackson is a well-known jackass
theres no emissions on a tranny and thats what the OBD1/2 systems are for. tranny sensors are useless (becids the VSS) i have 2 of 4 un hooked.
dopeassjackson is offline   Reply With Quote
Old 08-28-2006, 11:22 AM   #6
Xren17
Xren17 is an unknown quantity at this point
I believe you are wrong on that. There's the CPS on the S14 tranny used for OBD 2. Not needed to run but will throw a code.
Xren17 is offline   Reply With Quote
Old 08-28-2006, 11:29 AM   #7
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Release bearings are different also.
Jung918 is offline   Reply With Quote
Old 08-29-2006, 08:20 PM   #8
bigteddyted
I tried serching for it and i got nothihng. If you dont like repeating yourself just skip this thread and keep it moving to somthing that interest you. I didnt just ask without trying to look for it myself. thank you for your input and everyone elses even though some of it was uncalled for. now would i get some sort of check engine light is i dont connect the sensors??
Old 08-30-2006, 09:23 AM   #9
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
use an s14 manual tranny ecu. if thats possible.
hellion240sx is offline   Reply With Quote
Old 08-30-2006, 10:03 AM   #10
projectRDM
projectRDM's Avatar
That won't do anything, an S13 transmission won't have the CPS, so no matter what ECU is fitted it will still throw a code.
The correct way would be to put the S14 bellhousing on the S13 transmission and keep the CPS, but we all know this anyway.
Old 11-24-2006, 12:49 AM   #11
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i was wonderin the same thing. if all the tranny from 89-98 were the same, my tranny just broke down and ive been looking around to find myself a good condition dual head tranny for my 91 hatch. will 89-90 tranny will fit to a dual head one? without switching bellhousing and sensors? no mods need to be done? i heard people said itll fit and dont need to switch bellhousing. i just wanted to make it clear since sohc transmissions were everywhere in my place
Old 11-24-2006, 04:18 AM   #12
!Zar!
!Zar!'s Avatar
Did you miss the big black text?
Just in case.
Old 11-24-2006, 10:42 AM   #13
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
Russ, you should make that Tranny Note blink RED It's not being understood by some poeple
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 11-24-2006, 02:55 PM   #14
projectRDM
projectRDM's Avatar
I could make it life like and reach out from the monitor with a choke hold around their neck, still wouldn't do anything.
Old 11-24-2006, 06:50 PM   #15
wangan_cruiser
kouki man
Trader Rating: (36)
mah bad people well just wanted to make sure, but i respect all the reply...its just that some people say that u have to replace the bellhousing. ok since the big black text said it all....what do u do with the sensors? swap or what? i heard from other forums u have to check the resistant then go buy a resistor then solder it to the sensors....just need a proof it works
Old 11-25-2006, 04:05 AM   #16
projectRDM
projectRDM's Avatar
A resistor? For what? Where in hell are you reading this dumb shit?
Old 11-25-2006, 04:39 AM   #17
Wykydtron
Wykydtron's Avatar
Wykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really niceWykydtron is just really nice
It's for the actuator to discombabulated the flux capacitor. NightRider says "becareful not to touch turbo boost" at 88 miles per hour!
Dude you should be fine, the transmission is the same. If the harnesses end up being different, swap the s14 harness onto that transmission. Good luck sir
@schassis.eddi
Wykydtron is offline   Reply With Quote
