Old 02-26-2007, 09:47 PM   #1
lazymofo
lazymofo is an unknown quantity at this point
help SR injectors no pulse.
i got a s13 with a Sr blacktop.. i got the car running with a E MAFS. i was planning to drop a Z32 MAFS, which i did. after i spliced up the wires then turn the motor over, it idled about for a min. then it spubders then die. it wont turned back on again., i redid the harness. then still got nothing... check spark, good. check fuel presure, good. then i looked at the pulse. consant power no pulse.. whats going on here. i think i fucked up the wiring for the Z32 MAFS, then it causes a sensor to went out.
please help
stan
lazymofo is offline   Reply With Quote
Old 02-26-2007, 10:53 PM   #2
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
If you think you messed up on the wiring for MAFS why not start with fixing that.
Could be your ignitor chip is fried.
mRclARK1 is offline   Reply With Quote
Old 02-26-2007, 10:59 PM   #3
lazymofo
its really weird... its my firends car, the person who worked on the harness had worked on shit b4. i cleaned up the harness. redoing the whole harness. i drop the old E MAFS back on still doesnt work.. but why would the ignitor chip had anything to do with the injectors' pulse... i mean i got power to them. theres just no analog signal.
Old 02-26-2007, 11:04 PM   #4
mRclARK1
mRclARK1's Avatar
Never mind what I said about the ignitor chip.. for some reason I read "coilpacks" instead of "injectors" when I read your original post.
I'm obviously more tired than I thought.
Old 02-26-2007, 11:36 PM   #5
drftwerks
cam angle sensor, or crank, sheck those out
giantroboteyes.wordpress.com/
Old 02-26-2007, 11:40 PM   #6
drftwerks
the ecu should be pulsing the injectors on and off,
and get the signal to start firing the injectors from crank angle sensor.
check those, let us know what fixes them
Old 02-27-2007, 07:10 AM   #7
lazymofo
no problemo, ill do that asap
Old 02-28-2007, 02:19 AM   #8
lazymofo
any more ideas?
Old 02-28-2007, 02:35 AM   #9
johngriff
johngriff's Avatar
Smell your ecu, check for the on light. Check the ground wire of the maf harness.
Umm... what are you using to convert the maf with btw? Can I get an explanation of modifications?
[email protected]
Old 03-05-2007, 07:32 AM   #10
lazymofo
i used www.cameltoed.com i got slight confused by the mafs harness plug.
