![]() My car is running lean as soon as I get into positive pressure. It starts sputtering and hesitating and the engine makes a knocking sound. I am able to attain 7 psi.
This started happening directly after I changed out the dump pipe gasket and I got a new intake filter (not the piping). I don't understand how this would give me a problem. Here is the list of checks I have completed so far: • Swapped out the mafs twice • Inspected the intake tube for cracks • Inspected all couplers for the intercooler • Inpected fuel pump connector • Did a FPR test • Checked timing • Changed spark plugs • Inspected fuel lines • Checked for vacuum leaks • Swapped out ECU • Checked turbo for shaft play (none) • Checked BOV for leaks none (none) I thought it was a boost leak at first, but it does not appear to be since I checked all parts that would be associated with this problem. Is there something I missed other than engine internals. It seems like I am having a fuel pressure problem, or a sensor issue. Help please! |
![]() Join Date: Apr 2006
how do you know you are lean?
Are you running a wideband or any datalogging setup?
2015 Subaru Outback Overlander - Wagonofdoom |
No I am not running a wideband, but if the engine is knocking that seems to be a sign that I am running lean. Is there anything else it could be?
As I stated this started happening right after I changed the intake. Before I got a new intake I had an old K&N intake. I used the filter charger on it. Is there any other problem excess K&N filter charger can cause other than a fouled mafs and would it contribute to my problem? |
