Old 12-18-2006, 04:59 PM   #1
180sxsun
180sxsun's Avatar
180sxsun is a well-known jackass
KA Running Rich With Stock Fuel Pump
Can someone help me out! I recently took out the walbro fuel pump and put the stock one on, the car was running really rich thats why I put the stock back on, now it seems it made a difference but i still see black smoke coming out (not a whole lot), and my gas goin down fairly fast, could cams cause this problem or is there a place I can control (VIA MOTOR) the flow of gas?
180sxsun is offline   Reply With Quote
Old 12-18-2006, 05:11 PM   #2
kura
kura is an unknown quantity at this point
Send a message via AIM to kura
Caps lock will get you flamed here at Zilvia. Or ignored if you're lucky.
Edit: Sorry I can't be of more help to you. Just a suggestion that you may want to edit your post a little. ;D
kura is offline   Reply With Quote
Old 12-18-2006, 06:55 PM   #3
Panies
Panies is an unknown quantity at this point
Originally Posted by kura
Caps lock will get you flamed here at Zilvia. Or ignored if you're lucky. ;D
okay.
i'd start with the visual inspection to see if there's any fuel leaking. when you don't find anything, i would go with the tune up.
Panies is offline   Reply With Quote
Old 12-18-2006, 05:43 PM   #4
180sxsun
180sxsun's Avatar
thanx Kura for the heads up!
Old 12-18-2006, 06:10 PM   #5
Uknowwh707
Uknowwh707's Avatar
Uknowwh707 is a well-known jackass
oil change or tune up, maybe?
Uknowwh707 is offline   Reply With Quote
Old 12-18-2006, 06:37 PM   #6
mandoz85
mandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enoughmandoz85 will become famous soon enough
maybe one of your injectors is leaking, causing you to run rich? check your fuel pressure regulator, timing and do a tune up.
mandoz85 is offline   Reply With Quote
Old 12-18-2006, 07:08 PM   #7
180sxsun
180sxsun's Avatar
thanks for all the info ill do my best to check everthing out, and one more thing just to throw it out there, could the maf also be a factor?
Old 12-18-2006, 07:15 PM   #8
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
engine light on? maybe you should reset your ecu..
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 12-18-2006, 07:28 PM   #9
Markovich
Markovich's Avatar
Markovich is an unknown quantity at this point
coolant level good? is you coolant sensor for the computer good? that will cause it to run rich. also a bigger fuel pump wont make your car run rich unless your regulator is bad...
peace
7-mount sr20det evo3 16g in a 90 240sx coupe
yes its a nisclipse bitch
Markovich is offline   Reply With Quote
Old 12-18-2006, 07:40 PM   #10
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yea grab a fsm and follow the steps to check your fpr, also check your maf, and go ahead and check your spark plugs, because they might be fouled now since its been running rich
Slip Gypsies Blog
not sure if you realize this
Old 12-18-2006, 07:42 PM   #11
180sxsun
180sxsun's Avatar
i just change the plugs today the old ones were really black and was not gapped rite, it made a little difference but ill double check the fpr
jes jerk on it
