Old 12-29-2006, 04:34 PM   #1
MacDrevi0us
MacDrevi0us is on the path to ruinMacDrevi0us is on the path to ruin
i wonder what i did!?!
I have a 92' SE coupe and i was cleaning my interior and i guess i must have bumped my HUD(which has never worked) and all the sudden when i started my car to go to work it worked for the first time since i have owned the car, which was very exciting. However, as i drove for about 5 minutes it faded away and turned off again. Anybody have any ideas on what to do. I've searched but haven't found anything similar to this or anything that helped so i would appreciate it if someone had some advice. I would really like to have a working HUD!!
MacDrevi0us is offline   Reply With Quote
Old 12-29-2006, 05:25 PM   #2
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
If it turned on when you bumped it, it stands to reason that you just have a loose connection somewhere.... follow the wires...
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 12-29-2006, 06:55 PM   #3
MacDrevi0us
Ok thanks. I thought it was just busted forever but this gave me hope!!! I guess its cuz i bumped it but i was wiping down the dash with some cleaner then about 30 minutes later when i started my car it worked
Old 12-29-2006, 08:15 PM   #4
MacDrevi0us
ok so heres an update. I originally said it died shortly after i started my car the first time. I just left work and when i started my car as i was leaving it worked again but only for a short ammount of time like i said earlier. Then i pulled up to a stop light...turned off my car and turned it back on again and it worked AGAIN but this time only for about 5-10 seconds. Are you sure this is a loose wire or could it be a faulty capacitor not storing electricity?
Old 12-30-2006, 09:58 AM   #5
ms!3
probably still a loose connection, just take out the bezel around the cluster then take the cluster out to get to the hud wiring. or it could be something simple. have you checked your fuses?
ms!3 is offline   Reply With Quote
Old 12-30-2006, 02:55 PM   #6
MacDrevi0us
No I haven't checked them but i could do that too. I just thought it was something to do with the wiring cause it got bumped then magically worked. I'll check and write something back. Thanks for the help
Old 12-30-2006, 04:01 PM   #7
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
shouldn't be fuses. wires are probable
gotta240 is offline   Reply With Quote
Old 12-30-2006, 04:22 PM   #8
morbid
morbid is an unknown quantity at this point
hit it harder
morbid is offline   Reply With Quote
Old 12-30-2006, 04:26 PM   #9
johngriff
johngriff's Avatar
It is the capicitor which is broken.
I can repair this hud problem, but it is expesive and invasive. I can repair it for you for $200 w/ return shipping included.
Make sure you pull the cluster out, and test the pigtail harness first.
[email protected]
[email protected]
