Old 12-31-2006, 12:07 PM   #1
Flipzide
Flipzide's Avatar
Flipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfection
s13 Came across something while swapping out differential
I started taking apart my S13 differential yesterday to install my Kaaz 2 Way. After i removed the output shafts, i began to pull out the old oil seals. I tried using a screw driver to pull it out and when I looked inside, I found a circular spring.
I looked through a bunch of walkthroughs and even in my 1989-1990 FSM and I couldn't find anything in there about this piece.
Can anyone tell me what it's for? I bent it while trying to remove the seals when I wasn't looking inside the pumpkin. It was located between the seals and the side bearing adjustable washer.
D-Street.net | bcuison.wordpress.com
Flipzide is offline   Reply With Quote
Old 12-31-2006, 12:15 PM   #2
frankist
frankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura about
i dont remember seeing a spring unless your talking about the ring spring thats in the seal, that came out because you ripped apart the old seal.
frankist is offline   Reply With Quote
Old 12-31-2006, 12:20 PM   #3
Flipzide
Flipzide's Avatar
so thats what it is? i think thats what happened. it really had me bewildered for a while.
thank you.
Old 12-31-2006, 11:23 PM   #4
frankist
hope everything works out, im sure kaaz provided new seals. have fun with your new 2way.
