Old 03-31-2007, 10:35 PM   #1
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
rear swaybar installed...but understeer?
got my progress rear swaybar set to the stiffest setting which is equivalent of a tanabe bar.
went to test it out and normal driving the car is awesome, rear is really planted and more predictable.
i give me friend a ride and i do my usual stuff and do circles and shit, but i get crazy understeer. i have federal 595s in the front and some bald winter tires in the rear. i go from 1st to 2nd, and i turn in to start my circles and it won't even go sideways unless i clutch kick at least once or twice. before i was able to do it with ease.
whats going on? if i take a corner hard while gripping i wont understeer tho.
but when im doing some 60km/hr circles it understeers, i don't get it.
keep in mind i have stock sway bars on my s14. I'm running on springs and gr2s, so no coilovers.
i thought i would get some crazy oversteer but its actually the opposite affect.
i'll try again when i have time but i'm pretty sure this result will be the same again later on.
don't get me wrong i can still get sideways, but its leaning more towards an understeer. i cant even do 2 full rounds of a semi big circle without having to pop the clutch or ebraking it to extend it. before i just had to turn out and back in to get back sideways.
someone please enlighten me. thanks!
ps: could it be that the vlsd fluid wasn't warm enough? the engine was semi cold, not at the 1/2 way mark on the thermostat.
overb0ost is offline   Reply With Quote
Old 03-31-2007, 10:42 PM   #2
Gumballf355
Gumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to behold
Send a message via AIM to Gumballf355
It would be hard to help you without knowing your whole setup... being that your front tires are crap thats a large part of it.
Gumballf355 is offline   Reply With Quote
Old 03-31-2007, 10:42 PM   #3
LB.Motoring
LB.Motoring's Avatar
VLSD is where you should be directed.
Im sure it wasnt warm or something.
Unless you changed something else.
Robby Leuer
Old 03-31-2007, 10:53 PM   #4
overb0ost
overb0ost's Avatar
my front tires are federal 595s compared to some semi bald winters?
i would say the feds win by a large margin.
would it be that the rear is TOO stiff, causing understeer? since the car is more planted = more grip
the vlsd fluid was changed 10months ago to redline. went to 2 track events, and drifted in the winter.
maybe its the combination of my rear swaybar on full stiff + solid endlinks.
most people get tanabe but run polyurathane bushings, so theres still some room for flex as opposted to full solid endlinks? maybe it makes a huge difference?
Old 03-31-2007, 11:19 PM   #5
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
uh... Wow.. are you weight transfer any??
My S14 I'm stock front and whiteline in the rear sway bars and i'm stock spring with only gr2's in the front.
for tire traction T/A in the front with 85% left and used stuff in the back. There Poteza thingys...
What's spring are you running and how old are your shocks??
I pop oversteer easily if I do some weight transfer.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 03-31-2007, 11:50 PM   #6
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
Too stiff in the rear will not cause it to rotate around a turn thus causing understeer. Soften the setting up. So why did you upgrade the swaybar before doing the poly bushings?
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 03-31-2007, 11:57 PM   #7
1Via!
1Via!'s Avatar
1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all
Send a message via AIM to 1Via!
If you have stock struts, springs and a rear sway, there are other areas you should address before you start complaining about understeer.
Start with getting a front sway bar also.
1Via! is offline   Reply With Quote
Old 04-01-2007, 12:05 AM   #8
overb0ost
overb0ost's Avatar
^^ i actually got a front swaybar sitting beside me but i didn't have time to install it and i wanted to feel the difference with just a rear swaybar.
im not on stock springs and shocks, they are some aftermarket springs (yellow) and KYB Gr2s for shocks. car is lowered 2". car came lowered as is when i got it.
i noticed that i had more oversteer when off throttle, like gripping a turn when coming in hot.
but when trying to do circles at full throttle, all i got was understeer. even when i got it to get sideways it would catch grip every so often.
i'll probably end up setting it to medium and see how that does.
and about my front swaybar, it would probably add even more understeer wouldn't it? thats teh reason why i wanted to test having a rear swaybar then putting the front on.
Old 04-01-2007, 12:09 AM   #9
ronmcdon
ronmcdon's Avatar
hmm, usually isn't it the case that a stiffer and/or larger rear sway (or suspension for that matter) actually promotes more oversteer? or maybe your front swaybar is set to a position thats too tight? (edit* nm, read that you have stock front sways.)
by the way youre explaining things, it seems as though there's something not working right to begin with. my hunch is that it doesn't have anything to do with the sways, but i'm just guessing here. check out the simplest things first (set the sways to softest position, check tire pressure, check vsld fluid, check bushings, brake condition, etc)
as for the tires, you really ought to replace the them anyways if they're balding. might as well take care of it now for the sake of further diagnosis.
Old 04-01-2007, 12:19 AM   #10
overb0ost
overb0ost's Avatar
^ before putting the rear bar in everything was the same. was very easy to break traction. it seems harder to break traction now since it feels more planted on the ground. i'm thinking that maybe the chassis has stiffened up signifantly that now i cant drift low speeds without some sort of weight transfer.
and with bald tires, i should be spinning out. the rear tires would actually help with oversteer. i just want to drift them off till the cords and put new tires on the rims.
the things i will try in chronological order:
1) try again on a hotter night by myself, maybe it wasn't hot enough for the tires.
2) set it to the medium setting
3) change vlsd fluid
Old 04-01-2007, 01:30 AM   #11
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
you should install front sway bar too,
just increasing rears to some super stiff bar will lead to snap oversteer later on
other suspension components might help too
and you can't change the vlsd fluid, just diff fluid, the vlsd fluid will die out on it's on eventually and can't be changed....
all in all, seat time helps too, not sure if it's the weight transfer thing.. i had issues on that during my first time on track, it's like wtf, then i realized i suck...
Wei240 is offline   Reply With Quote
Old 04-01-2007, 03:56 AM   #12
McRussellPants
outside rear tire is loading up super fast causing the vlsd to shit its ass and freespin the inside.
done, VLSDs are only good when you're poor and have no mods.
McRussellPants is offline   Reply With Quote
Old 04-01-2007, 04:27 AM   #13
1Via!
1Via!'s Avatar
KYB GR2s are stock replacements.
Get an open diff. Weld it, or get one of your buddies to. You'll never have to wonder about whether your vlsd fluid it tepid, lukewarm, or boiling. And... youll be able to do your circles for days and days without having to worry about inconsistent results.
Old 04-01-2007, 08:41 AM   #14
overb0ost
overb0ost's Avatar
is the rear tire loading up super fast because of the swaybar is too stiff with the combination of my springs and shocks? if it was on a softer setting it wouldn't do so?
ya i got a nismo 2way that i'm going to install, just not sure when to install it.
i also have coils waiting but after i put on the swaybar it helped A LOT, so i was gonna go to a few track days first before i put on the coils.
i probably will install coils, then 2way.
Old 04-01-2007, 10:55 AM   #15
cdlong
how warm was it? if it was cold out, there's a good chance that the winter tires were gripping better than the fronts. the rears could have been in their operating range while the fronts were too cold to grip.
cdlong is offline   Reply With Quote
Old 04-01-2007, 02:22 PM   #16
McRussellPants
is the rear tire loading up super fast because of the swaybar is too stiff with the combination of my springs and shocks? if it was on a softer setting it wouldn't do so?.
probably a little, maybe maybe not.
Old 04-01-2007, 02:23 PM   #17
spool_sample
spool_sample's Avatar
spool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond reputespool_sample has a reputation beyond repute
A front sway bar will help balance the car out a TON. The common belief is that upgrading the front bar will make the car understeer more, which isn't necessarily always true.
On cars with crappy front suspension geometry (i.e. most cars with McPherson struts up front, like the S-chassis have), a bigger front bar will improve camber curves, thereby leading to less understeer as well as better turn-in.
Also, it never hurts to have the car realigned after working with the suspension. Crank up the camber and zero out the toe up front... maybe a little toe out if you don't mind the wear.
spool_sample is offline   Reply With Quote
Old 04-01-2007, 02:46 PM   #18
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
This is more than likely just bad driving coupled with inexperience and you expecting to feel a difference.
Also, your unknown springs and GR2 shocks (which are practically stock replacement) aren't too much of an upgrade
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-01-2007, 05:31 PM   #19
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Slight correction- not to nitpick, but a bigger bar doesn't change the camber curve, it just alters where you are on it. The only thing that changes the actual curve is altering the suspension mounting points, caster, etc. etc.
S13, SR20 - Track day fun
turtl631 is offline   Reply With Quote
Old 04-01-2007, 08:30 PM   #20
pr0tus
pr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymorepr0tus is not welcome here anymore
" i give me friend a ride and i do my usual stuff and do circles and shit, but i get crazy understeer. "
I don't know if you only tried this with your friend in the car, but I can tell you getting oversteer in my stockish 240 is way harder with a passenger. I have some fat friends though..
pr0tus is offline   Reply With Quote
Old 04-03-2007, 01:36 AM   #21
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
umm...........i thought macpherson strut design was superior. which is why porsche uses it front and rear. the only things better IMO would be cantilever, or pushrod setup.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 04-03-2007, 08:17 AM   #22
cdlong
BMW uses it too, but that doesn't make it good, it just means that porsche and BMW are good at macpherson struts. their camber curves aren't great (they don't gain enough camber during compression) and the travel is often short. but with a stiff spring, that doesn't matter as much.
the best setup depends on the vehicle and your definition of "best." but it's generally accepted to be an unequal length A-arm system like those used in formula one/indy/champ. push/pullrod/direct action usually has more to do with packaging and aerodynamics than anything else. with the right tuning, they can all be made to work more or less the same. i'm not really sure what a cantilever set up is, and a pushrod isn't really a complete setup, but a shock mount.
Old 04-03-2007, 10:00 AM   #23
!Zar!
!Zar!'s Avatar
Ugh. Why are we getting into the whole macpherson debate.
The understeer is coming from the vlsd.
Old 04-03-2007, 09:36 PM   #24
overb0ost
overb0ost's Avatar
what would you guys change first.
the vlsd to 2way
OR
my shitty springs and shocks to stance coilovers (already ordered them, so please don't suggest other brands)
i'm thinking coils....track a few times, then hit the 2way up.
Old 04-04-2007, 05:30 AM   #25
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
the vlsd to 2way
OR
Your tires first.
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 04-04-2007, 08:21 AM   #26
cdlong
is there something wrong with doing both? i'm all for seeing how mods affect the car seperatly, but the 2 way and coils will change the car enough that you will have to re-tune or re-learn the car. just put all the parts on then tune it.
Old 04-04-2007, 08:25 AM   #27
yokotas13
yokotas13's Avatar
exactly what i was thinking
that, and you rely on your body roll so much to drift without it you suck
tires
2way
coils
that order, go do it quit whining
yokotas13 is offline   Reply With Quote
Old 04-04-2007, 09:26 AM   #28
Replicant_S14
Replicant_S14's Avatar
Replicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of lightReplicant_S14 is a glorious beacon of light
Originally Posted by jmauld
Your tires first.
......and then drive it.... a lot.
I've gone from a stiff aftermarket rear bar, ...to a softer one, ....then back to the oe rear bar and inducing oversteer is never a problem. Give it a shot before you turn your car into this.....
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink.
Replicant_S14 is offline   Reply With Quote
Old 04-04-2007, 09:31 AM   #29
overb0ost
overb0ost's Avatar
tires
2way
coils
ok smart guy, tell me how do you drift an underpowered car without weight transfer? (yes there are other ways but weight transfer is the most efficient) You do realize body roll is a form of weight transfer right?
Old 04-04-2007, 10:12 AM   #30
yokotas13
yokotas13's Avatar
ive never drifted an underpowered car.
but i can tell you how im going to drift a fat ass overweight stagea with no body roll
22/20K springs
and 400 hp
