Old 02-02-2007, 10:12 PM   #1
koko
koko is a well-known jackass
anyone has problem with nismo on 350z with vdc?
anyone has problem with nismo on 350z with vdc? i am planning to get a set of nismo 18x8.5 25 offset and 18x9.5 30 offset? any one has them on a 350z track with brembo and vdc? and is there any problem with the vdc? and i am planning to put 225/45 on front and 245/45 on rear cause they are brand new tyres.
koko is offline   Reply With Quote
Old 02-03-2007, 08:53 PM   #2
Advent7
Advent7 is an unknown quantity at this point
Yeah as long as the front tire is around 1/4-1/2" lower then the front it works fine. I have 19" 9.5/10.5 and 255/35 and 285/35 and the VDC works fine.
You should at least go with a 245/35 275/35 maybe it was 40 profile but I was sure of the 245/275 combo setup unless you like the stretched look. If you go to any Z forum the people would say the same. I mean your practically getting the stock tire sizes on wider wheels.
I have a 03 touring but those wheels were designed for the Z and they should work with the track model.
Advent7 is offline   Reply With Quote
Old 02-04-2007, 08:16 AM   #3
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Yea the 245/40/19 & 275/35/19 combo will not throw the VDC off. Another thing, if you end up going wide in the back make sure you get an alignment b/c my Z seems to eat up wide tires on the rear with stock alignment.
sean350z is offline   Reply With Quote
Old 02-06-2007, 03:28 PM   #4
koko
[any pic of tyres stretched look and any disadvantage or danger?
