Old 02-03-2002, 10:22 PM   #1
Humungo
Humungo is an unknown quantity at this point
Here's the scoop, the key doesn't work in the slot because it's siezed, which is no biggie, but just this afternoon, the release lever beside the driver seat stopped working.  When I pull the lever, I can see that the latch still moves, so the cable is in one piece. It's hard to reach through the rear seats to work on the #### thing though. has anyone ever had this problem?? And how did you fix it?? It should be easy enough, but I don't want to torque on the latch and break it...guidance please!!
Humungo is offline   Reply With Quote
Old 02-03-2002, 10:43 PM   #2
Archangel
Archangel's Avatar
Archangel is an unknown quantity at this point
Send a message via AIM to Archangel
Its a bit of a crude way of doing it, but spray alot of WD-40 into the key hole, and work the key back and forth to loosen it up.
Archangel is offline   Reply With Quote
Old 02-03-2002, 11:03 PM   #3
Humungo
Yeah, that's what I plan on doing to the lock itself, but what about the release latch? I've tried reaching in and moving it around, but it doesn't seem to want to move to the left far enough to unlock the trunk?
Old 02-04-2002, 03:39 AM   #4
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
you have to move the little switch up and down.  youll see what i mean when the trunk is open.  you probably just went over a big bump and dislodged it
vancouvers14 is offline   Reply With Quote
Old 02-04-2002, 04:08 AM   #5
matic 240sx
matic 240sx's Avatar
matic 240sx is an unknown quantity at this point
yea and after you open it there is this little metal bar...  press it down and both will work... my cable stopped working so i had to open it with the key and in the latch hole there is a bar you can press down to make it work again
matic 240sx is offline   Reply With Quote
Old 02-04-2002, 09:21 AM   #6
Humungo
I've tried doing that with the latch, I can move it up and down about 1/4inch or so, how far should it move? And when it is fully pressed down, should it click firmly into place? Because when I try to pull it down, and then use the trunk release, it snaps back up, so am I not pulling it down far enough?
Old 02-04-2002, 01:02 PM   #7
vancouvers14
its like a half inch or something.  its definitely a click up and a click down.  just grease it and try again
Old 02-07-2002, 06:07 AM   #8
toddnappi
toddnappi's Avatar
toddnappi is an unknown quantity at this point
Send a message via AIM to toddnappi
My friend had this problem in his 95 Base. Luckily one of our friends is really tiny and crawled into the trunk and unlocked it. There's a lock or something on the inside that accidentally got triggered. Hope this helps.
toddnappi is offline   Reply With Quote
