Old 02-10-2007, 11:58 AM   #1
superfasteddie
superfasteddie's Avatar
superfasteddie is a jewel in the roughsuperfasteddie is a jewel in the roughsuperfasteddie is a jewel in the roughsuperfasteddie is a jewel in the roughsuperfasteddie is a jewel in the roughsuperfasteddie is a jewel in the roughsuperfasteddie is a jewel in the rough
Install went well, car runs like dirt
Okay here goes.
92 Ka-t , last night we installed my (very quick to arrive) Enthalpy ECU, 370's (new o-rings and pintle caps), N60MAF, new plug wires, new air filter, new plugs NGK BKR6ES gapped to 37*. Everything went in fairly smoothly, set the base timing to 20*ish. Not gonna lie, I have an ASP pulley, making my base timing questionable. All done, the car fired up after several cranks. Let it idle for 10-15 minutes, cleared it a few times and took the car out....eek. Idle is smooth at 8-900 ( I know, too high) but about the same as before the install, only smoother. Rolled on the throttle, boost builds and car falls on its face past 3500 RPMs, backfiring a ton and dumping smoke everywhere. Car is running super rich is all I can decipher. Gauge reads .50 bar so I know wastegate is working and boost is building, no air leaks, BOV works, but the car bogs down and falls flat=NO GOOD.
Any ideas? It was late last night so haven't mucked with it today. I was pissed, I went to bed..
NO FUEL LEAKS, no fuel smells.
I'm assuming the timing could still be off, we tried what looked like 20* and even 15-16*=same result.
Other mods
t-25
Walbro 255
FMIC
etc, etc.
Dip it and rip it...
superfasteddie is offline   Reply With Quote
Old 02-10-2007, 12:09 PM   #2
seekanddestroy
seekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choices
check for leaks in boost tubing, spray carb cleaner around joints while the car is idling and the idle will be effected if carb cleaner leaks in
seekanddestroy is offline   Reply With Quote
Old 02-10-2007, 03:56 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
also check to see that your maf is wired in correctly
Slip Gypsies Blog
not sure if you realize this
Old 02-10-2007, 05:05 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
get a timing light
do you have any kind of Air/Fuel meter?
Old 02-10-2007, 07:10 PM   #5
superfasteddie
Okay, have a timing light and I've adjusted it 15-25 degrees on the markings on the underdrive pulley. MAKES NO DIFFERENCE at WOT. I pulled the plugs and gapped them to .30, checked the MAF wiring three times, both grounds going to the same wire as well as grounding it to the chassis. EVen swapped to a buddies N62 MAF and it made NO DIFFERENCE. I'm at a loss. Everything produces the same result. Idles fine, roll on it, makes boost, car WON't pull past 2800ish RPMs and flat out falls on its face. Yesterday, previous to the install, she pulled fine. I do ot have A/F R readings, but judging by the tailpipe and the plugs (and the constant backfire) she is RICH, RICH, RICH.
Old 02-10-2007, 07:26 PM   #6
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Could it be your ecu? maybe they made a mistake.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 02-10-2007, 07:27 PM   #7
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
I would try searching for a leak somewhere, like seekanddestroy suggested. If you don't have a reliable way of testing for a leak, I could get you the same pressure tester I use pretty much every day. It's pretty inexpensive, reliable and has helped me find leaks that I had no idea existed. If you're interested, send me a PM. Good luck!
Turbo piping, Intakes and More:
http://www.pipingpro.com
Pepperoni is offline   Reply With Quote
Old 02-10-2007, 07:35 PM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
Check MAFS wiring/voltages?
Old 02-10-2007, 08:15 PM   #9
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
I agree, do this. Did you run this fuel setup NA first? This is always what I recommend to people incase of things like this.
Nizzan4u2nv is offline   Reply With Quote
Old 02-10-2007, 08:24 PM   #10
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
I'd say your running so rich that the car is just flooding itself, cut back fuel and see if it helps. What duty cycle are your injectors running?
ripnbst is offline   Reply With Quote
Old 02-10-2007, 09:14 PM   #11
superfasteddie
SOLVED!!!!! After just about calling it a night, we started seriously honing in on the boost leak theory. Checked and tightened every intercooler connection and unhooked the vaccum line to the BOV. End result= .7BAR and the car hauls apples. Reconnected the BOV vacuum and boom, super boost leak. MY BOV SUCKS. I didn't install it, just bought it that way. Ebay knockoff I suppose.
Old 02-10-2007, 09:34 PM   #12
reaxion
reaxion's Avatar
reaxion is making a name for him/her selfreaxion is making a name for him/her self
Send a message via AIM to reaxion
I know the feeling..make sure you buy quality. you get what you pay for.
reaxion is offline   Reply With Quote
Old 02-10-2007, 10:10 PM   #13
superfasteddie
Thanks, super relieved. Never driven the car at WOT for more than 10-15 seconds, will be nice to finally motor this baby a bit.
