Old 02-01-2007, 02:08 AM   #1
WhittSr20det
WhittSr20det's Avatar
WhittSr20det is an unknown quantity at this point
Maf???
sr20det blacktop
about 2 weeks ago i noticed my car was starting run more rich than usally, did a little tuning with my afc. Ran Fine this past week its hard to get started floods out pretty much, after i do get it goin it idle's like the dile ari control has gone out, then giving it gas i will have to pedal the gas until it stops falling on its face . Then when driving first gear from a stop is a nightmare it jumps bucks , but will go past 2500rpm. seconded gear it gets a little better, until i get at a general constant crusing speed then giving it gas to accelerate it will jump and buck ... then from there its back to the b/s. then comign to a stop it idles up and down like i said before.. then taking off the same thign as posted .. Runs ungodly rich u can smell it.... So I pulled my plugs , they were black went ahead and changed them . Same deal didnt help.. Fuel filter ... same thing ... im runnin a Walboro 255 fuel pump. Fuel pump is not the problem took another fuel pump i had for the car again a walboro same thing so its not the fuel filter plugs, so i ran codes it threw a 55 ...55 - Other Malfunction. CONSULT Terminal Required. Adjusted idle air , tps, still havent pressure tested for boost leaks cause then boost gauge only fluxuates on idle and still hits the 10 psi i have it set for?? any i deas?????
Sr20DetBlacktop
ACT stage 2..6 Puck Clutch
Front mount
Custom Hard Piping
GREDDY TYPE R.. No knockoff shit here
Super AFC
Auto Meter: BoostGuage,Water Temp,Oil Pressure
Megan Racing Dump Pipe
Megan Racing Down Pipe
Megan Racing Full Exhaust
Lsd
Falken Torque 5 Wheels
Front And Rear Suspension:
Kyb gr2 Struts
Cusco Camber Plats
Tein 2 Inch lowering Springs
Cusco Front and Rear Strut Bars
Blitz TwinSBC Boost Controller
WhittSr20det is offline   Reply With Quote
Old 02-01-2007, 07:07 AM   #2
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
i'd go ahead and check for vacuum leaks and or boost leaks and see what happens.
ladiesman8527 is offline   Reply With Quote
Old 02-01-2007, 11:21 AM   #3
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
A code 55 means NO MALFUNCTION.
(This is as detected by the ECU, The ECU does not test mechanical failures, only electrical.)
reactor is offline   Reply With Quote
Old 02-01-2007, 05:32 PM   #4
cotbu
cotbu's Avatar
code 55 means no sensor malfunction
you have a boost leak
Old 02-01-2007, 07:40 PM   #5
WhittSr20det
yeah thats what all mine friends were sayin and i was saying no i dont i just pressure stested it a week ago, so pressure tested it today no leaks.... so then took starting fluid sprayed all over my intake manifold car did change rev any higher... so any more ideas .. turbo?
Sr20DetBlacktop
Front mount
Custom Hard Piping
Super AFC
Lsd
Kyb gr2 Struts
Cusco Camber Plats
Old 02-01-2007, 07:54 PM   #6
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
is that seriously ur sig lol
boost leak or mafs
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 02-02-2007, 12:28 AM   #7
hondasrboring
hondasrboring is an unknown quantity at this point
could be injectors. I just had a problem with my one of mine. Had a progressively rough idle so i pulled the plugs and the #1 plug was black so i cleaned the plugs up and switched the #1 and #2 injector to see if the problem follows.
hondasrboring is offline   Reply With Quote
Old 02-03-2007, 09:46 AM   #8
North240
North240's Avatar
North240 is an unknown quantity at this point
It wouldn't hurt to look at the injector o rings, I wouldn't be surprised if they were looking a little rough. If not you only wasted 15 minutes.
ROUND 2
North240 is offline   Reply With Quote
Old 02-03-2007, 10:31 AM   #9
bouncin_180
bouncin_180 is on a distinguished road
maybe you got some messed up wiring for you maf connection ... if ever you start up and your having that problem pop yer hood wiggle yer wire n see if the prob goes away ... i thinking i kinda got the same problem ... my maf wire is like super duper long, my homie said im losing connectivity cause oh it being so long sometimes meaning a drop in voltage to the maf equal improper function ... basically saying your maf dont wanna work sometimes but since its like on n off its not gonna throw a code
bouncin_180 is offline   Reply With Quote
Old 02-03-2007, 10:45 AM   #10
kassed33
kassed33 is an unknown quantity at this point
s14
either your MAFS or your SAFC setting. Do you have it set for the correct engine? Do you have a tunned ECU? Pretty much all the correct startup settings for the SR20DET are in the book it comes with.
josh kassed
kassed33 is offline   Reply With Quote
Old 02-03-2007, 08:22 PM   #11
WhittSr20det
afc is fine ahvent changed anythign on the engine type... im leaning towards the maf ....
Sr20DetBlacktop
Front mount
Custom Hard Piping
Super AFC
Lsd
Kyb gr2 Struts
Cusco Camber Plats
Old 02-04-2007, 01:26 PM   #12
kassed33
r u using the SR MAF or a Z32 one, cause the Z32 one has to be set on the SAFC too, just to let cha know incase you didnt already...good luck
josh kassed
Old 02-04-2007, 09:52 PM   #13
kawika219
kawika219 is making a name for him/her selfkawika219 is making a name for him/her self
did you ever drop your maf??? i know my car acted like yours after i droped it...so i got another one
kawika219 is offline   Reply With Quote
Old 02-05-2007, 01:54 AM   #14
WhittSr20det
actually yes i did drop it a bit ago
Sr20DetBlacktop
Front mount
Custom Hard Piping
Super AFC
Lsd
Kyb gr2 Struts
Cusco Camber Plats
Old 02-05-2007, 02:55 AM   #15
kawika219
is this the 1st time using the maf after you dropped it??? if so, try plugging in another maf and see if it works better
Old 02-05-2007, 01:54 PM   #16
WhittSr20det
no its not , its been a while but since then its gotten progressivily worse... so i dunno i got income tax coming 1700 so i was goin to get a z32 maf new turbo and manifold all that good stuff im just tryin to figure out if that is it or it could be something else
Sr20DetBlacktop
Front mount
Custom Hard Piping
Super AFC
Lsd
Kyb gr2 Struts
Cusco Camber Plats
Old 02-11-2007, 10:36 PM   #17
WhittSr20det
full tank of bad gas lol problem solved runs fine now
Sr20DetBlacktop
Front mount
Custom Hard Piping
Super AFC
Lsd
Kyb gr2 Struts
Cusco Camber Plats
