Old 02-14-2007, 01:01 PM   #1
RUTH'LESSDET
RUTH'LESSDET's Avatar
RUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to all
Send a message via AIM to RUTH'LESSDET
s14 97 kouki auto idle troubles
...hey guys needs some help not a major issue but my car when warm at idle fluctuates between 500 rpm to 1000rpm. It’s never steady unless the car is cold wtf?? I’m trying to figure out what sensor it could be. The car also idles low about 475rpm to 500rpm, when I come to a stop. I could use some insight
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next?
RUTH'LESSDET is offline   Reply With Quote
Old 02-14-2007, 01:20 PM   #2
Taniguchi_Is_#1
check your MAF sensor. it might be dirty. clean it out with carb cleaner and see if that helps.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 02-14-2007, 01:54 PM   #3
RUTH'LESSDET
cool i will try that but could it be the aire idle control valve??
Old 02-14-2007, 02:19 PM   #4
Josh=s14
Josh=s14 is an unknown quantity at this point
Send a message via AIM to Josh=s14
I have the same problem on my 95
Josh=s14 is offline   Reply With Quote
Old 02-14-2007, 02:40 PM   #5
Dream240
Dream240's Avatar
Yeah it could be..... it could also be the EGR system. Try pulling apart the IACV first and cleaning it thoroughly and see what happens. Also replace the gasket when you pull it.
You could also have a vacumm leak somewhere in the system. Those are always fun to figure out.
Old 02-14-2007, 10:50 PM   #6
Gnnr
Gnnr's Avatar
Fuel Filter. My car did that before I changed it.
Gnnr is offline   Reply With Quote
Old 02-14-2007, 11:18 PM   #7
!Zar!
!Zar!'s Avatar
When was the last time you did something as simple as a tuneup?
Old 02-15-2007, 11:12 AM   #8
RUTH'LESSDET
I have not changed had one in a while but even when i did it did the same thing...but i have never changed the fuel filter.
