Old 07-21-2002, 06:09 PM   #1
PACO
PACO is an unknown quantity at this point
I have the power folding mirrors on my S14, and when I installed a new switch, the wires got gounded and now they won't work. The mirror glass moves, but they will not fold in. I wonder if the mirrors have some kind of built-in fuse, which could be busted? Please help!!!!
PACO is offline   Reply With Quote
Old 07-21-2002, 11:35 PM   #2
gschroeder78
gschroeder78 is an unknown quantity at this point
Send a message via Yahoo to gschroeder78
Hey Paco, I responded to you on FA but just in case anyone else here wants to know, I'm 95% sure there isn't an internal fuse in the mirrors so it's probably that you burnt out the motor the folds it in.  If anyone needs to know how to make the RHD mirrors work on LHD, let me know because if they stay RHD, they are useless. I didn't figure this out until I got them on and couldn't see out of either mirror.
1989 240SX Coupe
-Eibach Prokit Springs
-KYB AGX Struts
-Apex-i N1 Dual Exhaust
Westminster, CO
gschroeder78 is offline   Reply With Quote
Old 07-22-2002, 01:57 AM   #3
turbobunny
turbobunny is an unknown quantity at this point
GShcroeder...How do u make them work with LHD?  I just ordered a set and they should be here tomorrow.
Thanks!
turbobunny is offline   Reply With Quote
Old 07-22-2002, 08:06 PM   #4
PACO
Actually, I used the JDM Base and just swapped the mirrors.......I  can see fine........Also, thanx for the help
Old 07-23-2002, 01:22 AM   #5
Fresh 240SX
Fresh 240SX's Avatar
Fresh 240SX is an unknown quantity at this point
Send a message via ICQ to Fresh 240SX Send a message via Yahoo to Fresh 240SX
What do you mean u used the JDM base?
you just used the JDM folding mirror housing and put the stock mirrors in?
Hummm what did the set cost you? where did you order them from
Fresh 240SX is offline   Reply With Quote
Old 07-24-2002, 10:29 PM   #6
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Fresh 240SX @ July 23 2002,01:22)</td></tr><tr><td id="QUOTE">What do you mean u used the JDM base?
Hummm what did the set cost you? where did you order them from</td></tr></table><span id='postcolor'>
The actual mirror just snaps in and I noticed that the JDM mirror looks a little convex compared to the others so those are easy to switch but, I thought the whole problem with fitting the whole thing to a LHD car instead of a RHD car WAS the base. On the base, facing towards the front of the car, the plastic is more angled to cause the passenger side mirror to face in more. When the driverside switches, the driver mirror faces to far in and the passenger mirror faces too far out. The top part of the mirror is asthetically identical, the base is what is opposite. If you followed me on that one, your pretty smart cause I can barely understand what I'm saying. Just look at your mirrors, where they hinge and you'll see the difference.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 07-27-2002, 06:52 PM   #7
s13driver
s13driver is an unknown quantity at this point
i've been trying to swap the guts out of the jdm mirror since day 1 i got it.. i mean you just simply can't switch the housing around.. since it doesn't work that way.. just let me know if either one of you guys did something to it to make it work..
it is so hard to educate the uneducated.
s13driver is offline   Reply With Quote
Old 07-27-2002, 10:22 PM   #8
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (s13driver @ July 27 2002,6:52)</td></tr><tr><td id="QUOTE">i've been trying to swap the guts out of the jdm mirror since day 1 i got it.. i mean you just simply can't switch the housing around.. since it doesn't work that way.. just let me know if either one of you guys did something to it to make it work..</td></tr></table><span id='postcolor'>
Here is how I did and there might be other ways but this is mine.Remember, you basically have to sacrifice on set of mirrors to make them work.
1) You take the base from the USDM mirrors which is the triangular part that attaches to the door. There is a cover underneath it and three screws you have to remove. If there are electrical wires you have to remove the plastic connector on the end so you can pull them through the hole on the base (this is the hardest part).Don't forget to mark where the wires go in the connector. You do that on both sets of mirrors.
2)You'll have to mount the US bases to the JDM mirror but there is a little round tab that sticks up from the metal base which is supposed to mate to a small hole. This is where the 2 peices come together,and is supposed to hold everything solid while the mirror folds. The hole is now on the wrong side so you have to either drill a new hole (which I did) or file off the tab. The hole doesn't go all the way through so you kind of have to keep checking to see if it finally mounts flush.
3) &nbsp;Reassemble everything and it should look just like the stock mirrors did.
It looks like I might have over simplified this so feel free to ask for more details if you need to.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 07-27-2002, 10:25 PM   #9
AZN GTR
AZN GTR is an unknown quantity at this point
How much did you guys pay for them?
AZN GTR is offline   Reply With Quote
Old 07-27-2002, 10:28 PM   #10
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (AZN GTR @ July 27 2002,10:25)</td></tr><tr><td id="QUOTE">How much did you guys pay for them?</td></tr></table><span id='postcolor'>
I paid $150 + $25 for shipping. I think they've gone for a bit less but I did get the switch with it.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
Old 07-28-2002, 02:15 AM   #11
nizmo s14
nizmo s14's Avatar
nizmo s14 is an unknown quantity at this point
Can i PLZ c some pictures cause i'm not sure what power folding mirrors would look like folded. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'>
-Serge
nizmo s14 is offline   Reply With Quote
Old 07-28-2002, 02:26 AM   #12
gschroeder78
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (nizmo s14 @ July 28 2002,02:15)</td></tr><tr><td id="QUOTE">Can i PLZ c some pictures cause i'm not sure what power folding mirrors would look like folded. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'></td></tr></table><span id='postcolor'>
Take the mirrors on your 240 and fold them in and thats what they look like. The only difference is now their power folding mirrors.
1989 240SX Coupe
-KYB AGX Struts
Westminster, CO
