Old 02-21-2007, 07:48 AM   #1
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
Unhappy What can you damage from jump starting?
My '95 s14 has been sitting for 3 months so the battery was dead. A neighbor and I tried to jump start it and something went wrong. He hooked the cables up to the good battery first and it sparked when the neg. cable was hooked to my battery. After that, the high beams on my car came on even though the switch was off. The car still wouldn't start...
Thats what I get for being on the phone while he was hooking everything up
I'm thinking the harness shorted somewhere or the ECU is fried maybe?
FinalDrive is offline   Reply With Quote
Old 02-21-2007, 08:16 AM   #2
Dream240
Dream240's Avatar
Check your fuses.... sounds like he put the jumper wires on your car backwards.
Old 02-21-2007, 08:23 AM   #3
Taniguchi_Is_#1
x 2. cross your fingers and hope the fusible links didn't blow. they're kinda pricey.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 02-21-2007, 09:14 AM   #4
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Yea, sounds like they went on backwards. Did that to my car once, was really tired and not paying attention, thankfully, it only blew the main fuse.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 02-21-2007, 09:38 AM   #5
g6civcx
g6civcx's Avatar
Jump-starting, even when done "properly", may damage the entire electrical system of both cars, including all fuses and ECUs.
If you're lucky, you only blew some fuses, like what was said above. Check every single fuse in both fuseboxes again and see what happens.
Old 02-21-2007, 11:50 AM   #6
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
direct battery to batter neg connections can short shit out. If you ever notice when tow guys jump a car , they always attach the neg side to the car being jumped to a ground and not the battery neg gnd terminal. Batteries can also blow up directly connected. It can and does happen from time to time.
New Video
Buy my mounts!
Old 02-21-2007, 12:33 PM   #7
hello
hello will become famous soon enoughhello will become famous soon enoughhello will become famous soon enoughhello will become famous soon enough
Send a message via AIM to hello Send a message via Yahoo to hello
that's what i was going to say..
NEVER go battery to battery! next time find a better ground on your car.
just in case...
red=positve
black=negative
hello is offline   Reply With Quote
Old 02-21-2007, 01:16 PM   #8
Dream240
Dream240's Avatar
just in case...
red=positve
black=negative
Strut tower, just use the lip or one of the strut studs.
Old 02-21-2007, 01:57 PM   #9
g6civcx
g6civcx's Avatar
just in case...
red=positve
black=negative
This is helpful for 99% of the time, but don't rely on colour-coding to determine polarity. You never know what people do, including painting their battery terminals.
Don't even rely on the (+) and (-) markings either, because other parts of the world go backward from the US.
Look at the actual connections coming out of the battery terminals. Usually the hot side has a bunch of accessories drawing power, and the ground terminal goes straight to chassis ground.
Also don't count on the other guy hooking his battery up right either.
The bottom line is you never know how stupid some people can be.
Old 02-21-2007, 02:08 PM   #10
Skinner
Skinner is making a name for him/her selfSkinner is making a name for him/her self
the very first time i ever use jumper cables, i hooked them up backwards and my highbeams came on but i didnt think anything of it.. untill the the jumper cables started smoking and melting!
no damage was done to either car thank god.
Skinner is offline   Reply With Quote
Old 02-21-2007, 02:19 PM   #11
g6civcx
g6civcx's Avatar
The lights came on because light bulbs are non-polarity, i.e. they don't care which way current flows through.
When you hooked up the wires backward, you're forcing current to flow backward from the ground to the battery. The light bulb sees this and lights up.
The rest of your accessories, especially your ECU, do not like this backward flow of current!
