Old 02-22-2007, 02:35 PM   #1
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
Can I Hook Up My FPR Like This?
Hey guys i was wondering if i could set up my fuel pressure reg. like this. Please let me know if this has any drawbacks or anything.
Thanks, Jeff
-Jeff Wolfson
SpdElemts is offline   Reply With Quote
Old 02-22-2007, 02:36 PM   #2
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
so you want to leave your stock FPR in there??
redsuns3838 is offline   Reply With Quote
Old 02-22-2007, 02:37 PM   #3
SpdElemts
yea as a block off plate. It wont be hooked up at all and plugged up.
-Jeff Wolfson
Old 02-22-2007, 03:47 PM   #4
projectRDM
projectRDM's Avatar
Seriously think about that for a second. The fuel entering the rail is pressurized, you want it to reverse flow back out the same end and into a Tfitting? How? The rail is a one way valve, the only time it will reverse flow is when the pump is turned off.
What's going to happen in your case is 50% of the fuel will enter the rail and flow to the injectors, probably not enough and lean out the engine. The other 50% will immediately go through the new regulator and return to the tank, only to be split again once when it's pumped up front again.
If you turn your water hose on, do you expect water to shoot through the faucet back into the water supply?
Old 02-22-2007, 04:22 PM   #5
zenki-217
zenki-217's Avatar
zenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nicezenki-217 is just really nice
LMFAO!!!!!!!!!!!!!!!!!!!
zenki-217 is offline   Reply With Quote
Old 02-22-2007, 04:46 PM   #6
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
i have a ? about fpr too. can i use one of the sentre i know they have a sr20de. will it be the same as the sr20det.
grnappletree14 is offline   Reply With Quote
Old 02-22-2007, 04:55 PM   #7
YoungRookie
YoungRookie's Avatar
YoungRookie will become famous soon enoughYoungRookie will become famous soon enoughYoungRookie will become famous soon enoughYoungRookie will become famous soon enough
Send a message via AIM to YoungRookie
Not to hi jack your thread but can you run the fpr line to any vaccum source? Currently the line goes to one of the ports on the back of the block but it came dissconected one time and i didnt feel any vaccum on the line so i just wanted to run it to another source.
92 Hatch, KA-T, T28, 12 PSI, FMIC, 3" TBE, EFI ECU, 440cc Inj, And more...
YoungRookie is offline   Reply With Quote
Old 02-22-2007, 05:12 PM   #8
datboibrad
datboibrad can only hope to improve
well it depends on how you want to do it man. the ls1 setups work sort of like this. they fuel rail has no fpr on it. SOOO we use a corvette filter
the corvette fuel filter has a built in fpr. so what happens is when the fuel goes up in the filter then out to the rail it creates pressure. when the pressure reaches about 53 psi the diaphram opens in the filter bleeding off to the return line.
/edit. now that i look at what your wanting to do. its just not going to work at all lol.
datboibrad is offline   Reply With Quote
Old 02-22-2007, 05:14 PM   #9
datboibrad
any source as long as its from the intake manifold. you have several to choose from.
Old 02-23-2007, 12:06 AM   #10
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
This is one of the best ones I've seen for a while. . . lol
Just put it in line; no crazy Ts or anything are necessary lol.
cmcdougle is offline   Reply With Quote
Old 02-23-2007, 12:12 AM   #11
Ameer
Ameer is making a name for him/her selfAmeer is making a name for him/her self
true that.^^^^^^^^^^^^^
Ameer is offline   Reply With Quote
Old 02-23-2007, 02:36 AM   #12
!Zar!
!Zar!'s Avatar
Why reinvent the wheel?
