Old 07-22-2002, 11:13 PM   #1
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
ok i'm ordering a battery relocation kit for my 240 and i was wondering where you run the wires. i know it's fairly simple as far as ur just run the neg an pos connections to the back but how exactly do the wires get back there/ where are they run through?
thanx -dave
CoasTek240 is offline   Reply With Quote
Old 07-23-2002, 09:52 AM   #2
CoasTek240
CoasTek240's Avatar
*bump*
sorry
Old 07-24-2002, 04:04 PM   #3
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
run it under your car
I am GOD!
drifterx is offline   Reply With Quote
Old 07-24-2002, 04:25 PM   #4
Starlin
Starlin is an unknown quantity at this point
The kit will probably have instructions but if it does not this is what I'm going to do:
I'm just going to get a bunch of that wire harness wrap, ya know the round kind that is hard plastic, that is big enough for both wires and some zip-ties of the same color. Then I'm going to wrap the wires with it and run them along a brake line. Securing them to it with the zip-ties. Making sure to stay out of the way of moving parts and hot stuff. The brake lines are fairly hidden from view so the wires shouldn't be to easy to notice.
Anyone else got any better ideas?
Starlin
'89 240 SX: Chrome Tinted Windows/5 speed
'67 Ford Fairlane: Edlebrock:RPM Intake/Cam & Lifters/750cfm Carb/Alum. Heads/Alum. Valve Covers/Alum. Air Filter, Hooker Headers, Griffen Alum. Radiator, Mallory Ignition Sys, 9mm Ford Racing Wires, Flowmaster Exhaust + misc = 560hp/12.6 sec 1/4 Mile
Starlin is offline   Reply With Quote
Old 07-24-2002, 07:29 PM   #5
NissanNewbie
NissanNewbie is an unknown quantity at this point
You might try running them along the fuel line as those are usually pretty well protected.
NissanNewbie is offline   Reply With Quote
Old 07-24-2002, 10:24 PM   #6
Natty
Natty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (NissanNewbie @ July 23 2002,9:29)</td></tr><tr><td id="QUOTE">You might try running them along the fuel line as those are usually pretty well protected.</td></tr></table><span id='postcolor'>
*KABOOM!*
Hehe, be careful with the fuel lines. I am sure it is safe, but I am paranoid.
What about the box for the battery? And where do you mount the box? I may do this. Free up some room up there, maybe help my weight balance a wee bit too.
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 07-24-2002, 10:52 PM   #7
CoasTek240
CoasTek240's Avatar
is there a place in the firewall so i can run the lines through my car.. also the kit i ordered came with all the neg and pos lines braided ans sealed with new connectors and zipties.. also a box for the battery and a mounting kit in the trunk
Old 07-24-2002, 11:00 PM   #8
xhdriver
xhdriver is an unknown quantity at this point
just drill a hole in the fire wall and run the line in the car under your carpet, you only have to run the positve, because you can ground the negative in the trunk.
xhdriver is offline   Reply With Quote
Old 07-28-2002, 03:08 AM   #9
gemoose23
gemoose23 is an unknown quantity at this point
Send a message via Yahoo to gemoose23
I am currently doing a battery relocation also in my car, and I was told for Track and Tech Purposes, the POsitive wire has to be run inside the cab of the vehicle.
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;Still need to get a holesaw to cut my firewall... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
GeMoose23
92 GSX
91 240sx
00 TL1000R
gemoose23 is offline   Reply With Quote
Old 07-28-2002, 07:41 AM   #10
CoasTek240
CoasTek240's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (xhdriver @ July 24 2002,01:00)</td></tr><tr><td id="QUOTE">just drill a hole in the fire wall and run the line in the car under your carpet, you only have to run the positve, because you can ground the negative in the trunk.</td></tr></table><span id='postcolor'>
ok i'm kinda retarded.. what do u mean u can ground the neg in ur trunk.. can u explain a little better?..
i got the running th epos.. but i'm really confused bout the neg.. how will he car have both neg an pos connected.?.. huh? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'>
Old 07-28-2002, 04:25 PM   #11
huevos
huevos is an unknown quantity at this point
maybe this will help?
huevos is offline   Reply With Quote
Old 07-28-2002, 04:34 PM   #12
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (CoasTek240 @ July 27 2002,09:41)</td></tr><tr><td id="QUOTE"><!--QuoteBegin--xhdriver+July 24 2002,01<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (xhdriver @ July 24 2002,01<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>0)</td></tr><tr><td id="QUOTE">just drill a hole in the fire wall and run the line in the car under your carpet, you only have to run the positve, because you can ground the negative in the trunk.</td></tr></table><span id='postcolor'>
i got the running th epos.. but i'm really confused bout the neg.. how will he car have both neg an pos connected.?.. huh? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/blush.gif" border="0" valign="absmiddle" alt=':blush:'></td></tr></table><span id='postcolor'>
hes right all you need to run is the pos. wire the ground off the battery atachs to the body of the car i would use the seatbelt bolt best ground in the area!!
come on this is not rocket science <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
my240likenoother is offline   Reply With Quote
Old 07-28-2002, 06:03 PM   #13
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
hrmm..y do u relocate the battery for anyways?
SilviaDriver is offline   Reply With Quote
Old 07-28-2002, 06:47 PM   #14
my240likenoother
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (huevos @ July 27 2002,6:25)</td></tr><tr><td id="QUOTE">maybe this will help?</td></tr></table><span id='postcolor'>
SilviaDriver
Status: Offline
Group: Members
&nbsp;Posted: July 27 2002,8<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>3 &nbsp; &nbsp;
read!!!!!
Old 07-28-2002, 09:24 PM   #15
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
why do you guys want to drill hjoles for? either go thru the grommet located in your driver side fender(when you remove the wheel well you can see it) opr go thru the grommets that your ac was? dont know about that though. i would go inside the car never on the outside with a wire so essential to starting your car
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 07-28-2002, 09:52 PM   #16
SimpleS14
SimpleS14's Avatar
where did you buy this kit from?
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
