Old 07-27-2002, 10:28 PM   #1
Apparition
Apparition's Avatar
Apparition is an unknown quantity at this point
Send a message via Yahoo to Apparition
I want to reduce the vertical length of the shifter. Its too high, as I have to reach around it to change the tracks on my cd player. I'd like the knob to sit about an inch lower, yet look good. I don't have to cut the knob, then it look dorky.
Will aftermarket knobs shorten the height? I know a short shifter reduces the shift throw, but does it also reduce the height?
Need suggestions, this is on a s13 btw.
1990 240sx coupe *sold*
Apparition is offline   Reply With Quote
Old 07-27-2002, 10:33 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
from what I remember, the stock shift knob extends a bit... so some aftermarket knobs might help, but probably not by much.  Cutting an inch or so off the shifter would make a bigger difference though.
If you cut the threads off the shifter, you'd probably need an aftermarket knob that uses set screws, though.
AceInHole is offline   Reply With Quote
Old 07-28-2002, 12:08 AM   #3
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Yes, aftermarket short shifters do reduce the vertical length of the shifter, nothing to drastic but noticable.  You probably would want to go with B&M or C's short shifters.
Blitz!!
kanekz is offline   Reply With Quote
Old 07-28-2002, 11:58 AM   #4
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
can someone link me to where i can pick up a C's ss. thx
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 07-28-2002, 02:08 PM   #5
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
Cutting the shifter isnt a good idea in most cases.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess
Ni5mo180SX is offline   Reply With Quote
Old 07-28-2002, 04:06 PM   #6
mrdirty
mrdirty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Ni5mo180SX @ July 28 2002,3:08)</td></tr><tr><td id="QUOTE">Cutting the shifter isnt a good idea in most cases.</td></tr></table><span id='postcolor'>
dunno about most cases but I cut down a pilot short shifter and it works great on my 240.
mrdirty is offline   Reply With Quote
Old 07-28-2002, 07:44 PM   #7
Apparition
Apparition's Avatar
so all that being said, which is the ideal shifter to lower that vertical height about an inch or so?
Old 07-29-2002, 09:47 AM   #8
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Apparition @ July 28 2002,8:44)</td></tr><tr><td id="QUOTE">so all that being said, which is the ideal shifter to lower that vertical height about an inch or so?</td></tr></table><span id='postcolor'>
B&M. I have the OBX in my car right now. It's getting swapped this week for the B&M that's sitting in my living room. I can tell you just by looking at it that the shifter is shorter in height. Oh and the throws are SOO short and precise. www.enjukuracing.com has the newly revised B&M's for sale. tell ken that eric spread the good word....
Eric
EDIT: &nbsp;just for clarity...the OBX is a copy of the C's. &nbsp;so the C's will have the same height and throws as the OBX. &nbsp;it's just higher quality.
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
