Old 01-02-2002, 03:27 AM   #1
Nismo S14
Nismo S14 is an unknown quantity at this point
Has Greddy released its turbo yet and is th XS engineering turbo faster or a s13 sr20det?
Nismo S14 is offline   Reply With Quote
Old 01-02-2002, 07:13 AM   #2
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
Gredy has not released the turbo kit fot our car yet.But as far as axs-enginnering and an sr20det its whatever you choose.The enging can handel up to 14psi from what i hear but then again i am not sure and if you want to get some power outof you car witha turbo put together a homemade kit not hard to do.It is cheeper that way as well.I belive the ka engine can run 10psi with stock internals without a problem.But that imo on turbo setup.
BEISSEN is offline   Reply With Quote
Old 01-02-2002, 08:12 AM   #3
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
IIRC TY in AZ is running 13psi on his KA (FMAX stage 2) with 550 cc injectors and a stock bottom end.
uuninja is offline   Reply With Quote
Old 02-01-2002, 07:07 PM   #4
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
It's a lifelong question: SR vs. KA. Some people like the torque and the powerband of the KA, some like the SR. The truth is that you'll be making the same power with lower psi-s with a turbo on your KA as the other person will with their SRs. This is what I've noticed at least.
As far as KA turbo kits go: Beissen is right.  You'll probably come off with more money in your pocket if you do it yourself. However, when you buy a ready kit from a company, you always have a place to go with questions and anything else that might bother you. But again, if you have experience with KAs and turbo applications, then you should be bothered with that.
S13Grl is offline   Reply With Quote
Old 02-03-2002, 03:06 PM   #5
Guest
Posts: n/a
hey my one question on a KA vs. SR is would the sr have more of a top end?  the KA would rev out, wouldn't it?
Old 02-03-2002, 03:37 PM   #6
Sway500
Sway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to all
you really cant compare the 2 because one has a T04 and the other has a T25 tubine which are totally different.
Sway500 is offline   Reply With Quote
Old 02-03-2002, 05:04 PM   #7
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
sway500 writes......
__----------------------------------------------------------------------
errr wrong. KA turbo setups use T3/T4 hybrids not T04's
Old 02-03-2002, 09:11 PM   #8
Takumi
Takumi's Avatar
Takumi is an unknown quantity at this point
GReddy's using a TD06, XS (as well as F-Max) is using a T3/T4.
Takumi is offline   Reply With Quote
