Old 03-01-2007, 07:49 PM   #1
jin8544
jin8544's Avatar
jin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-known
95 S14 5spd conversion
Can i do it?
and how can i do it?
what are the things that i need?
Im thinking about buying auto and convert it to 5spd
jin8544 is offline   Reply With Quote
Old 03-01-2007, 08:01 PM   #2
Akiros
Akiros's Avatar
Akiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfection
Send a message via AIM to Akiros
depends on the person / search / search / good for you
Akiros is offline   Reply With Quote
Old 03-01-2007, 08:05 PM   #3
sTalnOut
sTalnOut's Avatar
sTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nicesTalnOut is just really nice
Send a message via AIM to sTalnOut
wat do u wanna dooooooooo ?
sTalnOut is offline   Reply With Quote
Old 03-02-2007, 12:15 AM   #4
jin8544
jin8544's Avatar
i want to go from auto to manuel
Old 03-02-2007, 12:21 AM   #5
azndummie
azndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant future
well if u wanna go from an auto to a mexican thats kinda hard. u gotta find a manuel first.
azndummie is offline   Reply With Quote
Old 03-02-2007, 01:09 AM   #6
sw20>>s14
sw20>>s14's Avatar
FAQ!!!!
lookaroundjeez
sw20>>s14 is offline   Reply With Quote
Old 03-02-2007, 01:10 AM   #7
drftwerks
honestly if you have to ask, you probably shouldnt try it
giantroboteyes.wordpress.com/
Old 03-02-2007, 01:13 AM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
I got a cousin Manuel. hahha
Old 03-02-2007, 02:13 AM   #9
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
need:
5 speed tranny and mount
clutch kit with pilot bearing and 5 speed flywheel
slave cylinder, clutch hard lines, master cylinder, clutch peddle assembly
5 speed driveshaft
extra: 5 speed brake peddle assembly or just cut your automatic one (it will sit higher than the clutch peddle).
manual shifter trim and boot.
Your 5 speed tranny shouldn't have any oil in it, if it does; drain it.
drain tranny oil, unbolt drive shaft, unlink the shifter cable, remove oil lines to radiator, unplug wires to sensors on tranny, unbolt the tranny from the motor, unbolt the tranny mount. drop the tranny, remove engine under cover to access the 4 bolt holding the torque converter, pull out the automatic pilot bearing.
put on 5 speed fly wheel, pop on the manual pilot bearing, put on the new clutch, greese the pilot bearing hole, put on the new throwout bearing on the tranny and greese the clutch fork pivot ball. put the 5 speed tranny on, mount the tranny mount and driveshaft.
Get into the car and remove the shifter assembly, tape up the shift lock cable in OPEN position (so you can remove the key, you can pull it all out if you want). Pour 2.5 quarts of GL4 gear oil (redline mt90) into the tranny and mount the shifter, mount the boot and ring, now mount the shifter boot and trim.
Go under the driver side dash and cut a hole for the clutch master cylinder, there are indentions for it. Pull the automatic trans ECU down there too. Once done, mount the clutch peddle assembly and master cylinder, install the hard lines, Under the car, bend the lines so it faces the slave cylinder if neccessary (sometimes they're facing towards the back of the car because of a damping line). Bleed the slave cylinder and attack the wiring.
http://www.ka24development.com/cwilf...lectrical.html
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-02-2007, 09:37 AM   #10
EAS13
EAS13 will become famous soon enoughEAS13 will become famous soon enoughEAS13 will become famous soon enough
Search!!! You will get hammered if you don't spend 1-5minutes finding info on this forum for yourself.
I'll be nice, here's all the info you need:
http://www.zilvia.net/f/showthread.php?t=21181
EAS13 is offline   Reply With Quote
Old 03-02-2007, 10:22 AM   #11
kenshinS14sks
kenshinS14sks's Avatar
kenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to behold
holy jesus on a bike i was thinking the SAME THING!!!
facebook.com/SodiumDanceCompany
kenshinS14sks is offline   Reply With Quote
