Old 03-07-2007, 11:16 AM   #1
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
won't crank, no power to fuel pump
I turned the key to on/acc/start, then before the motor could start to crank all warning lights,fuel pump, etc. went dead. I disassembled the ignition switch to see if that mite be the case, seems okay. Only functions that work are all hot-constant ones, such as interior light, headlamps, brake lamps, hazards.
BTW I did search bitches. We need to make an electrical gremlin sticky thread under tech.
Update, replaced ignition switch and that did nothing to hep my situation.
Anyone have any ideas as to what else could be the problem.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 03-08-2007, 12:10 AM   #2
sideview_180sx
anyone else have this problem. dammit im desparate. it my dialy driver too. total stock central.
Old 03-08-2007, 12:22 AM   #3
Mrmagics13
Mrmagics13 is an unknown quantity at this point
well, what did you do? (swap, change something etc...?)
Mrmagics13 is offline   Reply With Quote
Old 03-08-2007, 12:38 AM   #4
Flybert
I'd first try by replacing the grey 75amp fuse in the engine bay. That will probably fix your problem. I remember something like that happened to me once and that was my solution. Did you cross your battery cables?
Old 03-08-2007, 12:43 AM   #5
Mrmagics13
thats what i was kinda thinking, or either that that battery terminals arent tight, sometimes, this is tha case, the car will turn on acc. when you go to start it will click and die, check battery leads.
Old 03-08-2007, 08:58 AM   #6
sideview_180sx
nope. battery leads are super snug. this is my daily driver. i don't drift it. don't mod it. just put gas, and oil changes.
to mrmagic
Originally Posted by sideview_180sx
anyone else have this problem. dammit im desparate. it my daily driver too. total stock central.
Old 03-08-2007, 09:20 PM   #7
sideview_180sx
problem fixed. I had already replaced all relays and fuses under the hood. and it still didn't start. then today i just hopped in and turned the key and it fired up. fuck i hate this shit. who knows if/when it will happen again.
