Old 08-01-2002, 04:05 AM   #1
MasterOFDrift
MasterOFDrift is an unknown quantity at this point
Send a message via AIM to MasterOFDrift Send a message via MSN to MasterOFDrift
My breaks squeek every time I use my brakes what causes this? warpped rotors?What can i do to fix the squeeking. It is very loud
[edit] spelling and grammar errors
MasterOFDrift is offline   Reply With Quote
Old 08-01-2002, 10:17 AM   #2
Natty
Natty is an unknown quantity at this point
There is a tiny speing or piece of metal fitted into the pad that starts to contact the rotor when the pad is almost gone. This is called a wear indicator. It starts squeaking to let you know you need new pads. You have about 3,000 miles to replace the pads or your screwed &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 08-01-2002, 10:40 AM   #3
Nerfdude
Nerfdude is an unknown quantity at this point
that's not true... at least, not in my experience. the wear indicator makes a horrible scraping noise, seeing as to how it's a piece of metal dragging along your rotor... the squeaking could be wear, could be brake dust. could be something i don't know. welcome to the wonderful world of disc brakes, kid.
get yourself a can of Brakleen and hose em down. that'll probably do the trick.
Nerfdude is offline   Reply With Quote
Old 08-01-2002, 11:26 AM   #4
240racr
240racr is an unknown quantity at this point
Send a message via Yahoo to 240racr
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Natty @ Aug. 01 2002,09:17)</td></tr><tr><td id="QUOTE">There is a tiny speing or piece of metal fitted into the pad that starts to contact the rotor when the pad is almost gone. This is called a wear indicator. It starts squeaking to let you know you need new pads. You have about 3,000 miles to replace the pads or your screwed <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Jeff</td></tr></table><span id='postcolor'>
This is correct. The wear indicator WILL squeal. That is if you are lucky. If you have some cheap ass pads, inspect them once in a while. The old pads I had were cheap and the wear indicator broke off, so I didn't know I needed new pads. Well, I wore into my rotor. So I had to replace them. (good reason to upgrade to Brembo cross drilled <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> )
Precision T3/T4, 65lb injectors, z32 brakes, AEM EMS, 360WHP
240racr is offline   Reply With Quote
Old 08-02-2002, 01:00 AM   #5
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
i have the same problem. &nbsp;i replaced them about 4 months ago and ever since then ive been hearing the damn squeel. &nbsp;i even used the grease stuff thats suppose to stop the noise. &nbsp;that didnt work. &nbsp;im going to get a can of brake cleaner and do what you say and hose them down.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
