JDM Wing question - broken studs
Hey everyone,
I tried searching but didn't find anything on this topic. I bought a used JDM kouki wing for my s14 and the stud on one side of the wing (marked in red) is smaller (likely cut off). It needs to be longer so that I can secure it to the car. Any advice on how I could fix this? I'm adding images for context. Appreciate the help! Here are the pics: https://imgur.com/a/5tHM8Qp Last edited by ragamuffin; 03-29-2022 at 03:31 PM.. Reason: updating car model info |
![]() Join Date: Jun 2003
Trader Rating: (130)
Chop it down and have someone weld a new one to the stub of the old one.
Or press the old one out and install a nut-sert, and then use a bolt from underneath to attach. Last edited by brndck; 03-29-2022 at 04:40 PM.. |
#5 | ||
If I decide to sell, I'll let you know. I waited years to find one local to me. |
![]() Join Date: Aug 2005
The way I mounted my Kouki wing in the past was with 3m double-sided tape + stud/nut. It will be similar if you did the nut-sert like brndck said.
![]() Join Date: Dec 2006
If you're worried about the nut-sert not holding onto the plastic that well, you could always remove that broken stud, and then drill an access hole near where the stud was. you could feed another bolt through, and with a little patience, get it sticking out of the original hole where the stud was. You can use a pushnut washer to hold the new stud in place. Once done you can then plug up the access hole with a rubber plug if you'd like.
Tags |
jdm, kouki, s14, spoiler, wing |
