Old 03-10-2007, 03:56 AM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
What is this fitting for?
This is a little unknown fitting on the intake manifold of 93 KA24DE.
Any one know what this is for? I hooked my FPR signal line onto this and it was not creating vacuum. Just for curiousity before I plug this.
jafero is offline   Reply With Quote
Old 03-10-2007, 04:26 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
Narps, duh.
Originally Posted by PHLIP
Old 03-10-2007, 08:27 AM   #3
projectRDM
projectRDM's Avatar
That is the FPR vacuum port, could be clogged with something.
Old 03-10-2007, 01:44 PM   #4
jafero
So that is the one!
I don't feel like to penetrate the fitting. I am afraid of damaging the cylinder with foreign object.
Can I direct FPR signal line onto some other vacuum source, say brake booster line by making a T and let it share vacuum source with this FPR?
Old 03-10-2007, 01:59 PM   #5
chmercer
chmercer's Avatar
that sounds retarded. spray carb cleaner into the hole
chmercer is offline   Reply With Quote
Old 03-10-2007, 02:33 PM   #6
projectRDM
projectRDM's Avatar
Bingo. Stick the straw down in the hole and blast it clean.
Old 03-10-2007, 06:25 PM   #7
jafero
Thought about doing this but what if the fitting is clogged by something hard? Since it can't be taken out of intake manifold, wouldn't this go into cylinder chamber and damage the piston or the chamber?
Old 03-17-2007, 08:37 PM   #8
MAGILLA
MAGILLA's Avatar
MAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enoughMAGILLA will become famous soon enough
some thing hard like what? as long as you have an air filter on the car nothing hard should be there. just grime from the egr, which the cleaner will melt.
MAGILLA is offline   Reply With Quote
