Old 03-18-2007, 05:16 PM   #1
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
s14 300zx brake hardware
Alright, I'm having a little trouble scavenging up the brake hardware for my 300 zx swap on the front. The parts I can't find is the clip and cross retainer thing that goes under the slider pins. I checked autozone and advanced auto. Advance auto had the shims and pins. Has anyone just used cotter pins and not installed the cross retainer?
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 03-18-2007, 05:28 PM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
i heard of ppl just using a paper clip
and then twist it
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 03-18-2007, 05:32 PM   #3
ThatGuy
Admin Asshole
ThatGuy's Avatar
See if this helps.
http://www.courtesyparts.com/z32_brakes.html
If you don't want to order from them, just take the part number and price to Don Williamson on Western Blvd. They "should" match the price.
Old 03-20-2007, 05:30 AM   #4
camppain
camppain's Avatar
Only problem is I called the Nissan where I worked at and they don't even make the part no more when I talked to my buddy in parts. But I'll try them I'm sure the results will be the same, can't hurt to try though. Thanks brother.
Old 03-20-2007, 06:38 AM   #5
mrmephistopheles
mrmephistopheles's Avatar
It's high time you became a premie, Leathernuts.
Originally Posted by PHLIP
Old 03-20-2007, 06:43 AM   #6
portion
portion is an unknown quantity at this point
www.pdm-racing.com
portion is offline   Reply With Quote
Old 03-20-2007, 07:26 AM   #7
Dopefish
Dopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really nice
Send a message via AIM to Dopefish
You have to get them from Nissan or a Nissan vendor... I'll look up the numbers for mine tonight as I have all that stuff for my install; still waiting on the slider pins themselves.
You are talking about the little wire retainers on the left of this pic right?
EDIT: Call Courtesy Nissan and have them look up this part number: 41218-43P00, that should be for the retainers pictured above.
_Kris
It never got fast enough for me. -Hunter S. Thompson
Dopefish is offline   Reply With Quote
Old 03-21-2007, 01:27 AM   #8
camppain
camppain's Avatar
MrMeph, long time brother. Did you hear how the Marine Corps is turning into the girl scouts? Sleeves won't be allowed anymore. I've been contemplating re-enlisting. Premie ehhh? In due time, in due time .
I called Nissan Dopefish, I called my old job which was at a nissan dealership, talked to my buddy in the parts dept and he said no go on the part #'s when I get some time I will call them back up with the part #'s from courtesy. Especially since the pins I got from advanced auto seem like they are for the 28 mm calipers when I asked for the 30 mm :\
Old 03-22-2007, 10:16 AM   #9
Dopefish
I just realized, I think I only have the rear pin retainers. I'll call Courtesy tomorrow once I've varified which ones I need and I'll get both part numbers for you then.
_Kris
Old 03-22-2007, 03:03 PM   #10
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
_Kris
Yep those pins are for ther rear
rancid240 is offline   Reply With Quote
Old 03-23-2007, 01:49 PM   #11
Dopefish
Yea I only had the rear pin retainers, no matter... I bought a small cotter pin set for $3 at Autozone and one in each pin on the front calipers is holding them in just fine. Since there wont be any actual stress excerted on them other than vibration the cotter pins should be more than capable.
Front retainer clip: 41217A
Rear retainer clip: 44217A
Good luck, again, I just used cotter pins on my fronts and they are snug. ...sadly I can't install anything yet because Courtesy left out one of my rear retainer pins from my order (even though it's in the PO) so my entire install is on hold.
_Kris
