Old 03-25-2007, 06:59 PM   #1
a_ahmed
a_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfection
speedo not working (unique circumstances)
So I bought an impul 260km/hr speedo for an s13 about half a year ago off ebay. In that timeframe I got married, went on a three month honey moon, stored the car for winter, etc...
I finally got around to installing the speedo about a week ago... what happened to my horror was that the speedo itself didn't work.
Anyways I was lazy to take it out since, and what I did was just leave it. What was happening was that the speedo jumped to the first needle point (10km before the bigger jump to 20km) and then just be stuck there and ocassionally bump down to 0 as I'm driving but when I'm at a stop jump to that first 10km line.
Anyways today I took it out and gave it to my father to inspect. He found out that the needle was slightly on an off angle.. in other words if you blow on the needle it was going hard, so he said it was mechanical. I assumed first it was something electronicly related, like a capacitor or resistor, I wouldn't know. Half an hour later, he managed to fix that by luck although the chances were so slim. So now when it's blown on it rotates fine. The speedo was shook around as well to test if the needle is going to sink in or anything like that, and well, it's fine now. It blows normally and falls back down on it's own.
I put it back in the car and what happens? As soon as I crank the car OR turn the key to give the car battery power... the needle jumps to the 20km line and stays there.
I took it out for a spin, and what hapens? Well first it stays there, then it kind of reduces itself and eventually as I really drive, it reduces itself to 0. When I come to a stop it goes back to the 20km/hr.
This is gay.. I don't want to go back to a standard 180km/hr speedo after having this in the car for the last 3 weeks or so lol... plus it was money spent...
I want to fix it/get it fixed... what's up... help me out people...
a_ahmed is offline   Reply With Quote
Old 03-25-2007, 07:03 PM   #2
RoyalFlush
RoyalFlush's Avatar
RoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura aboutRoyalFlush has a spectacular aura about
theres your problem
jk i have no idea though, thats wierd
RoyalFlush is offline   Reply With Quote
Old 03-26-2007, 12:34 AM   #3
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
My suggestion is to first check your speed sensor on the transmission. Disconnect it from the wiring harness and start your car. You'll have no tachometer, but take it for a spin. If the speedometer is doing the same thing, then you know the problem isn't related to your speed sensor.
I would then go over your wiring with a fine tooth comb - check everything to make sure that you wired it up properly, grounded it properly, and that none of the wires are touching each other. If everything looks fine, then take your speedometer off your car and install it temporarily on another car. See if it does the same thing on the new car.
Just some suggestions, hope this helps.
s13_gearhead is offline   Reply With Quote
