#2 | |
![]() Join Date: Apr 2004
Yes, I have an E throttle cable, and on the SR it has to stretch across the valve cover. A technician at a local shop told me that his car has a DE cable, and it is routed nicely around the back of the valve cover and firewall without stretching over the top.
by switching the cable, you're just changing the apperance of it. instead of having it over your valve cover.
when changing cables, the throttle bracket will be different too.
![]() driftingisgay.com |
#6 | |
ok good well some kid told me that it was a de cable and he sent me a E cable so im kinda pissed... im also not getting any spark after swapping in my DE motor... i replaced the coil, cap and rotor, plugs and wires and still nothing... should i check the voltage going into the coil to find out if there is even any juice going there? the car turns over but nothing else happens. It turns over really well like it wants to but when i checked for spark i had none.
it's your dizy and/or wires to it. when you converted to DE and did the so call wiring. all those wiring do is just signal the relays to turn the starter (trigger accessories and sensors). It has nothing to do with spark. You just have something not connected.
