Old 03-22-2007, 01:39 PM   #1
mr.sideways
mr.sideways's Avatar
mr.sideways is an unknown quantity at this point
ka engine shut down after highway trips
so i have a 89' 240 w/ a ka24e. and after long trips on the highway when coming to a stop the car just shuts off. the first time it happened was tuesday and it hasn't stopped. i do need to do a radiator flush so is that problem. i change spark plugs and wires, used air intake cleaner on throttle body. what else could it be. AAA said possibly alternator. but it starts and i am thinking it may be the fuel injectors. pls help. thank you
mr.sideways is offline   Reply With Quote
Old 03-22-2007, 01:48 PM   #2
IcedOutSoulja13
IcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enough
Send a message via AIM to IcedOutSoulja13
is ur check engine light on? check ur whole fuel system...check anything electronic that u may have messed around with maybe it shorts out or something
IcedOutSoulja13 is offline   Reply With Quote
Old 03-27-2007, 12:40 AM   #3
mr.sideways
check engine light is not on. but i will f*** around with it this weekend and keep you posted
Old 03-27-2007, 12:49 AM   #4
LB.Motoring
LB.Motoring's Avatar
I will help you.
Most likely, like me,
I had this exact problem.
after checking my ECU, turns out my CEL was on becouse i have a coolant temp sensor go out,
and it made my car die after driving it, then coming to a stoplight, then it has a hard time i even trying to start back up,
ka24e also.
chk into it,
its an ez fix usualy
just keep eliminating problems,
sometimes even fixing problems before hand.
Robby Leuer
