Old 07-31-2002, 06:13 PM   #1
Natty
Natty is an unknown quantity at this point
When braking, my steering wheel shakes like mad. Warped rotors I guess. Anyways, my KVR pads from PDM came in and I need to go to the parts store. Rotors are about $25 a piece.
Should I just get the fronts or do it all? I would ike to save $50 if possible. Can I visually tell which is defective?
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 07-31-2002, 09:12 PM   #2
gsu240
gsu240 is an unknown quantity at this point
Send a message via AIM to gsu240 Send a message via Yahoo to gsu240
rotors are $25 a piece? damn, what kind are you getting? because that seems extremely cheap to me.
when my rotors were warped they made a grinding noise when i applied my brakes.  you can get the rotors turned or reground by any brakes place, probably about $50 for all four rotors. the only way you will need to replace them is if they are just extremely warn or have been turned several times.
A one night stand will last until morning, syphilis will last a lifetime.
gsu240 is offline   Reply With Quote
Old 07-31-2002, 11:12 PM   #3
Natty
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (gsu240 @ July 30 2002,11:12)</td></tr><tr><td id="QUOTE">rotors are $25 a piece? damn, what kind are you getting? because that seems extremely cheap to me.
when my rotors were warped they made a grinding noise when i applied my brakes. you can get the rotors turned or reground by any brakes place, probably about $50 for all four rotors. the only way you will need to replace them is if they are just extremely warn or have been turned several times.</td></tr></table><span id='postcolor'>
AutoZone rotors &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
I am a cheap bastard &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Jeff
Old 08-01-2002, 06:39 AM   #4
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
I'd save the money and just do the fronts for now. &nbsp;They do most of the work so rears aren't as prone to warpage or other problems that cause vibration. &nbsp;
The other thing it might be up front are glazed rotors - this happens when pad material from low quality pads bonds to the rotor. &nbsp;If you drive hard w/ el cheapo pads, this can happen very easily. &nbsp;You'll be able to spot it by shiny or dark smooth spots on the rotor that you could chip off if you worked at it. &nbsp;I hear emory cloth will take it right off.
HippoSleek is offline   Reply With Quote
Old 08-01-2002, 07:17 AM   #5
bbp
bbp's Avatar
bbp is an unknown quantity at this point
replace, don't bother turning them.
don't use high temp pads on a street car. &nbsp;they will not work as well as an OE pad, and shorten the rotor life.
bbp is offline   Reply With Quote
Old 08-01-2002, 10:19 AM   #6
Natty
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bbp @ July 31 2002,09:17)</td></tr><tr><td id="QUOTE">replace, don't bother turning them.
don't use high temp pads on a street car. they will not work as well as an OE pad, and shorten the rotor life.</td></tr></table><span id='postcolor'>
KVR are not really that high temp. And everyone says they work fine for a street car and are quite rotor friendly &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/dozingoff.gif" border="0" valign="absmiddle" alt=''>
I do plan on replacing the front rotors now. I'll just resurface the rears cause I am getting new pads.
Jeff
Old 08-02-2002, 02:35 AM   #7
Itsuki
Itsuki's Avatar
Itsuki is an unknown quantity at this point
i was looking at NOPI.com and they sell brembo rotors for like 25 dollars each... not sure if they are real brembo's but it says they are, has anyone orderd them???
Itsuki is offline   Reply With Quote
Old 08-02-2002, 09:32 AM   #8
adey
adey's Avatar
adey is an unknown quantity at this point
As far as I've heard, the "Brembo" rotors sold at Nopi.com are NOT brembos; they're either cheating you or have made a typo. I don't remember the actual name of the manufacturer though. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 08-02-2002, 12:04 PM   #9
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
the way you can tell if its from the front or rear is by simply applying the hand brake and see if the problem is there when you apply it that way or just when you put your foot on the brake. btw warped rotors will cause pedal pulsation not steering shake.
turning rotors isnt bad as long as they are within spec's.
*edit* or if you have a dial indicator you can tell if the rotors are warped <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> but i dont think everyone wants to dump 180 into one <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
Old 08-02-2002, 12:46 PM   #10
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (adey @ Aug. 02 2002,10:32)</td></tr><tr><td id="QUOTE">As far as I've heard, the "Brembo" rotors sold at Nopi.com are NOT brembos; they're either cheating you or have made a typo. I don't remember the actual name of the manufacturer though. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
they are in fact Bradi rotors. &nbsp;A sister company of Brembo. &nbsp;Quality is fine. &nbsp;Ask Steve (240 2NR) about them as he just installed a set last week.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
