Old 03-30-2007, 07:24 PM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
chance of cylinder head being warped
I need to change head gasket due to over heating issue. Both coolant and oil is mixing. However, my compression readings for all cylinders come out at around 185 psi. This probably means portion of head gasket around water pump is torn.
With this great compression reading, is there a chance that the head is warped and needs to be machined? If not, I want to use the same head and same studs.
jafero is offline   Reply With Quote
Old 03-30-2007, 09:40 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
when my car overheated alot it warped the head but the compression was not that bad. this was on a ka the head and head studs where warped. hope that helps.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 03-30-2007, 10:42 PM   #3
jafero
Thanks a lot.
So you overheated your car a lot... I never raised coolant temperature above 97 degree celcius. I just figured that it was overheating as coolant temp went above 90 degree. So my chance of warping my head should be minimal, right?
