Old 03-22-2007, 08:08 PM   #1
Eric240sx1990
Eric240sx1990's Avatar
Eric240sx1990 is an unknown quantity at this point
Crankshaft pulley removal
Well I had not been able to work on my car for about 2 weeks now and finaly went and got the "pulley removal kit" from autozone.
It had a remover and an installer...
thing is it was the wrong one, and they didnt have a part number for another one that would work.
Does anyone know the part name or number for this.. I cant find it anywhere and the fsm doesnt say which one to use...
I know it has to be the design that hooks around the pulley and applies force with a bolt...
thanks for any help
Eric
1990 240sx s13 ka24e OHHH YA!!! In the process of rebuilding
2002 F.o.r.d. Focus SVT All-Weather package, Steeda STS, Cool flow, borla catback, 3" ss dowmpipe, H&R cup kit, Front upper and rear upper Focus sport strutbars Focussport 9 mm wires, Denso iridium plugs,
Eric240sx1990 is offline   Reply With Quote
Old 03-22-2007, 08:12 PM   #2
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
i thought u just remove the bolt...
benefitx is offline   Reply With Quote
Old 03-22-2007, 09:02 PM   #3
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
just get a Huge pully remover...
tap it with a hammer a lill.. and pull
i once used a smaller puller and it broke 2 parts of the crank.. but the second try it came right off..
Chrischeezer is offline   Reply With Quote
Old 03-22-2007, 09:32 PM   #4
projectRDM
projectRDM's Avatar
Thread the OE bolt back in a few turns, then use the puller. You need something to press against so it can pull straight out. Any 6" or larger 3,4 jaw puller will work fine.
Old 03-22-2007, 10:36 PM   #5
Eric240sx1990
and whats the best way to get the oe crank bolt off. everything ive tried has failed and i dont want to break the crank or damage the pulley.
Ive tried putting the trany in reverse and seeing if that would provide enough leverage to break it loose. that didnt work and it was starting to make the car roll a little bit, even with the ebrake on..
some help on that would be awesome too
Old 03-22-2007, 10:39 PM   #6
pwhitersxs
pwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enough
Send a message via AIM to pwhitersxs
How about a impact wrench? That should work just fine.
s13 sr20det
pwhitersxs is offline   Reply With Quote
Old 03-22-2007, 10:43 PM   #7
Irukandji
Have a friend step on the brakes while you use a hugeeeee lever arm.
Old 03-22-2007, 10:46 PM   #8
Eric240sx1990
well, there isnt a 24v impact wrench that can apply enough force for this one trust me...... i dont have the access to a compressor so i guess ill try the brakes and cheater bar idea... that might work.
Old 03-22-2007, 10:52 PM   #9
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Nikeboy355 is offline   Reply With Quote
Old 03-23-2007, 03:19 AM   #10
aznpoopy
aznpoopy's Avatar
um yah ^
throw a breaker bar on it. car in 5th, brakes on. its actually not hard at all.
Old 03-23-2007, 03:42 AM   #11
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
or just brace the breaker to something secure, remove the FP fuse, crank the car once, and bam, instantly loose. pry the crank slowly back and forth and it'll come right out.
Make sure not to drop or loose little crank pulley holder. Its like a metal C that sits on the crank, where the pulley sits. Easy Peasy.
I threw the socket on there with an extension, braced it with a tire, closed teh hood, and cranked it. Worked like a charm.
SochBAT is offline   Reply With Quote
Old 03-23-2007, 02:05 PM   #12
Eric240sx1990
well, my engine is already torn down to the block and just the front cover and crank pulley. All i gotta do is get this thing off and the oil pump/pan and im good to rebuild the timing assembly. ima try the high gear + brakes and breaker should work
Is it allright if the crank moves like 40-50 degrees while this is happening? When I was trying the other day it was moving, even in rev. and ebrake.
thank you everyone uve been an awesome help
Old 03-23-2007, 03:15 PM   #13
projectRDM
projectRDM's Avatar
Is the oil pan off? wedge a pry bar into the crank from underneath to keep it from rotating.
Old 03-25-2007, 02:42 PM   #14
Eric240sx1990
i havent taken the pan off yet, but that is a good idea
Old 04-05-2007, 03:03 PM   #15
Eric240sx1990
Thanks u guys so much!!!
That was easier than I thought, just had to put it in 5th friend held brakes down, e brake on and huge cheater bar.
the 3 claw did easy work of the pulley too. I tapped it with a rubber mallet very softly around the perimeter of the pulley and it just wobbled right off.
But... Lastly, are there any hidden bolts on the front cover? Cant find a fsm for the sohc with the engine diagram in it. I loosened all the ones that i could see... but it wont budge. I still need to go get a seal breaker if its needed.
Thanks again guys!!
Old 04-05-2007, 04:26 PM   #16
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
not sure about the KA, but the SR has 2 bolts in the upper oil pan and 2 bolts inside the head holding the front timing cover on
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
