Old 04-11-2007, 12:23 PM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
oil restricter fitting
for all of you guys who run oil restrictor fittings for your bottom mount turbos. will the taka or circuit sports line fit the restrictor. or i'll have to get a AN fitting to make it go on the restrictor. if i do what is the AN size fitting and is it the male or female fitting.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-11-2007, 12:31 PM   #2
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
it usually comes with Taka lines.
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 04-11-2007, 12:48 PM   #3
s13silvia123
so i see thanks man but what about the circuit sports lines do they come come with the oil restricter fitting.
Old 04-11-2007, 02:29 PM   #4
LookOut Nick
LookOut Nick's Avatar
LookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond repute
nope, cs lines do not come with the restrictor to my knowledge.
if you need it for a bb turbo you can order the .03 restricter made by taka from heavy throttle ...other wise bottom mount t25 ss lines by cs are direct bolt on
Team Pterodactyl
LookOut Nick is offline   Reply With Quote
Old 04-11-2007, 03:57 PM   #5
s13silvia123
i'm not running a t25 at the moment i'm running a gt2540R right but i havent put any lines on cause i figured it out i needed a restrictor thats why i didnt put on cause i needed it. now i've just order the CS lines and the restrictor. will i need a AN fitting to fit both on with each other or is it just a direct bolt on.
Old 04-12-2007, 04:37 PM   #6
bgindn
bgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud ofbgindn has much to be proud of
Send a message via AIM to bgindn Send a message via Yahoo to bgindn
restriction fitting
The restriction fitting I had custom machined will fit right on to my exsisting Taka lines. However you can use them with any -3 oil line. They restriction fitting gets threaded right into the turbo.
Will my restriction fittings fit the CS lines? They should if the oil line is -3.
If you want to see a picture of the restrictor up close, check out my webpage, hopefully the pics answer your questions.
harp
bgindn is offline   Reply With Quote
Old 04-12-2007, 05:12 PM   #7
s13silvia123
plus one for everyone who helped me.
