Old 04-16-2007, 08:25 AM   #1
Project3328
Project3328's Avatar
Project3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud ofProject3328 has much to be proud of
s13 240 died this morning (electrical)
my battery light came on and hids started flashing then the car shut off.. any ideas.. also there was a buzzing sound under the dash
Project3328 is offline   Reply With Quote
Old 04-16-2007, 09:21 AM   #2
projectRDM
projectRDM's Avatar
1) battery
2) alternator
Did you really need to ask?
Old 04-16-2007, 09:22 AM   #3
chmercer
chmercer's Avatar
hmm maybe charge the battery hmm. or check some fuses... hmm. hmm or, something
chmercer is offline   Reply With Quote
Old 04-16-2007, 04:03 PM   #4
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Yeah do those things for sure, battery and alternator, but also check your ignition relay. Brown relay attached to the under dash fuse box on the side.
.. Friends don't let friends drive stock...
smily_vigor is offline   Reply With Quote
Old 04-16-2007, 04:16 PM   #5
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
check to see if your alternator belt is still attached to the alternator pulley...
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 04-16-2007, 04:24 PM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
As pointed out already... Your alternator is probably fried (or the belt is shredded). Then you ran the car off the battery until you drained it, which is probably why it's dead now and the starter won't turn over.
MELLO*SOS is offline   Reply With Quote
