Old 03-19-2007, 09:30 PM   #1
S14_306
S14_306 is an unknown quantity at this point
s14 JDM kouki bumper problem
Hi, I just got my car back from the body shop and the 97 JDM kouki front bumper does not fit the usdm bumper support.
Anybody know where I can actually purchase the 97 JDM bumper support and the energy absorber or where to cut and weld the udsm bumper support so that the jdm bumper fits.
Now i've been driving my car for 2 weeks and bad idea, the bumper is getting loose due to all the bumps and ditches. Theres a 1 inch gap now between the bumper and the headlights. Any advice? thanks
S14_306 is offline   Reply With Quote
Old 03-19-2007, 09:38 PM   #2
projectRDM
projectRDM's Avatar
Cut the ends off past the forward posts.
Done.
Old 03-19-2007, 09:43 PM   #3
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
odd, i didn't have to do anything. I'm not running any bumper foam. Did you use the USDM kouki upper retainer? that holds the bumper up closer to the headlight.
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-19-2007, 10:55 PM   #4
S14_306
yah Im using the usdm kouki retainer. cus i converted from zenki frontend.
Old 03-19-2007, 11:10 PM   #5
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
I doubt your using all the usdm kouki parts... I think you missed something when doing the swap.
I used all usdm kouki parts and just didn't use the foam..(cause it wont fit)
gotta240 is offline   Reply With Quote
Old 03-20-2007, 12:03 AM   #6
S14_306
thanks, hmm damn i gotta find out what Im missing. Is it even possible to fit the foam. Has anyone done it?
Old 03-20-2007, 12:10 AM   #7
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I was thinking about shaving the foam part but I think it would take too long. It is there for small impacts. If you shave it, it defeats the purpose. I decided to just leave it off.
Jung918 is offline   Reply With Quote
Old 03-20-2007, 09:09 AM   #8
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Are you using the kouki bumper support? The kouki bumper support when mounted is about an inch higher than the zenki support when mounted. Here is a pic of mine. Do your brackets angle up somewhat? If so its a kouki support, if they angle down its a zenki support. Hope this helps.
C. Anderson is offline   Reply With Quote
Old 04-12-2007, 12:44 AM   #9
floodo1
floodo1 will become famous soon enoughfloodo1 will become famous soon enoughfloodo1 will become famous soon enough
Sorry if i'm being a bit ignorant here guys, but please bear with me. i've tried searching as best I can, and I just want to make sure i'm clear here.
I have a 97 so it definately has the kouki bumper support and usdm energy absorber foam.
will i have to modify the bumper support?
floodo1 is offline   Reply With Quote
Old 04-12-2007, 12:48 AM   #10
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Yes. You need to cut it.
Says so on Jspec.com as well if you want another reference.
Old 04-12-2007, 12:49 AM   #11
floodo1
also a quick question about turn signals.....again sorry if my ignorance offends you....
the reason I ask is that someone hit my car in the front, and I'm having a local body shop do repairs, and im switching to jdm oem front bumper at the same time since I will save a nice chunk of money because the insurance is covering some parts costs.
Do the jdm turn signals plug directly to the stock usdm (kouki) turn signal wiring? Do i need to change plugs or anything?
Old 04-12-2007, 09:20 AM   #12
ziptiedae86
ziptiedae86's Avatar
ziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfection
Wiring up JDM kouki signals:
http://www.zilvia.net/f/showthread.php?t=114133
The pictures don't work anymore but the instructions are there and easy to follow.
ziptiedae86 is offline   Reply With Quote
Old 04-12-2007, 11:30 PM   #13
floodo1
ty soo much!
