Old 04-16-2007, 06:47 PM   #1
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
sparco seat brackets
i need to buy some seat brackets for my bottom mount sparco non-reclinable seat. i was gonna get one custom made but that shit was taking too long and costing like $150+. i already have the sliders but i need a bracket that bolts to teh floor. titan sells 2 brackets and i can't figure out what the difference is and everytime i call they are closed
this is the bracket i was gonna order
http://store.titanmotorsports.com/nisebr.html
but then found this and got confused
http://store.titanmotorsports.com/spsebr1.html
slideways2004 is offline   Reply With Quote
Old 04-16-2007, 08:13 PM   #2
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I got a Sparco EVOl and the shop that installed the seat used Sparco mounts and welded them to the stock feet of the rail system.
Slide Happy
chuy is offline   Reply With Quote
Old 04-16-2007, 08:18 PM   #3
godzillarb
godzillarb's Avatar
godzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to all
I had originally made some brackets that were basically the same as the oem ones, but the seat sat entirely too high for me. I'm 6' and my head was half and inch from the roof. Anyways, to got the seat to sit lower because I set the brackets slightly under the support beam that the original seat brackets attach to. I welded my new brackets which bolt to the sliders to that support beam.
If you want the seats extra low its going to cost big time, unless you're a badass and can make stuff yourself.
INTENSE POWER RIPPED ME OFF
godzillarb is offline   Reply With Quote
Old 04-16-2007, 08:52 PM   #4
slideways2004
i want to get teh sparco mount and just bolt it to the seat w/o sliders. i will mod the bracket to fit me and the seat will be hard mounted
Old 04-16-2007, 09:01 PM   #5
eastcoastS14
eastcoastS14's Avatar
how tall are you....i have 2 bottom mount rails i have one that is welded from the stock rails with metal plates xing over it making it a bottom mount....hard to describe but it works came on my car with my sparco fighter seat if your short itll work fine ill sell it to you for cheap if you want it...i also have a bottom mount bride rail i picked up from aspec trying to sell that too but its more expensive...figured id throw that out there...lmk
eastcoastS14 is offline   Reply With Quote
Old 04-16-2007, 10:03 PM   #6
slideways2004
pm me a price for both. i'm 6'1"
Old 04-17-2007, 03:26 PM   #7
slideways2004
so does anyone know the difference between these 2?
Old 04-17-2007, 03:36 PM   #8
Frosty_spl
Frosty_spl will become famous soon enoughFrosty_spl will become famous soon enoughFrosty_spl will become famous soon enoughFrosty_spl will become famous soon enoughFrosty_spl will become famous soon enough
i have sparco sprint seats, and im getting my friend to fab me up some superlow brackets. If you use sliders it will sit up alot higher. Im 6'3 and my car has a sunroof, so I need as low as possible.
IM not paying 400 for brackets either, thats retarded.
Frosty_spl is offline   Reply With Quote
Old 04-17-2007, 03:53 PM   #9
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
i used stock mounts modified for my old sparco sprint. it sat way to high and there was no way i could put a helmet on
i suggest a bride rail just cause they sit low and you won't have a problem at all
Ca_laurier is offline   Reply With Quote
Old 04-17-2007, 04:43 PM   #10
slideways2004
yeah, i'm not using sliders. my car is a hatch with no sunroof= the most headroom other than a vert w/ the top down.
i'm weighing out my options right now. i might buy some metal and just make them myself.
Old 04-18-2007, 11:50 PM   #11
slidecrave86
slidecrave86 is an unknown quantity at this point
i got some sparco seats and the kid gave me some brackets but they are from a civic and the passenger side.. but the part that bolts up screws on the the bracket so can't i just take those off and then use the stock ones and either weld them on or just screw them on some how and be done with it or will this still leave me sitting high i'm only 5'9" would i still be ok... thanks and sorry for kinda thread jacking
slidecrave86 is offline   Reply With Quote
Old 04-19-2007, 09:16 PM   #12
kclo4
kclo4 is an unknown quantity at this point
slideways2004, you have a PM.
I have a passenger set of the Nagisa auto side mount rails which are killer.
kclo4 is offline   Reply With Quote
