Old 01-26-2004, 04:35 PM   #1
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
does s13 front lower control arms fit on a s14`
i got n an accident juss by the tire, and i messed up the front control arm. nd i saw new s13 front control arm for 50 dollars so i wanted to know if it could fit on a s14. and if it doesnt does n e one know were i could find the control arm for a s14. i found one were the mechanic was selling, he was selling used ones for 75 dollars and new ones for 150 dollars each. so if n e one knows can u please post by feb 15.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 01-26-2004, 04:36 PM   #2
Dousan_PG
Dousan_PG's Avatar
no.
s14 has wider track (the LCA is longer) and the ball joint is different.
Aaron
Pink GodziRa
Old 01-26-2004, 04:44 PM   #3
XxJaPxOxNeEs23xX
do u know were i could find it. nd is da price too high or low
Old 01-26-2004, 04:46 PM   #4
Dousan_PG
Dousan_PG's Avatar
for s14 LCA? not sure
s13 one is like 50ish..www.pdm-racing.com sells s13 ones (i dont think they sell s14 ones)
check online junkyards for used s14 FLCAs
Aaron
Pink GodziRa
Old 01-26-2004, 04:49 PM   #5
XxJaPxOxNeEs23xX
o nd sorry i ddnt see the other threads dat had da same exact question. but i still dont know were i can get it. thanks
Old 05-10-2007, 03:26 AM   #6
serdaman
serdaman can only hope to improve
Can i use my s13 spindles by pressing an s13 ball joint into the s14 lca? or do i need the spindle to do the swap?
serdaman is offline   Reply With Quote
Old 05-10-2007, 04:10 AM   #7
projectRDM
projectRDM's Avatar
For? Unless you like a shitload of positive camber you can't use an S13 LCA on an S14, period.
Old 05-10-2007, 10:36 AM   #8
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
The s14 ones are a little over $100 each.
Jung918 is offline   Reply With Quote
Old 05-10-2007, 10:58 AM   #9
SwiftS14
SwiftS14 is an unknown quantity at this point
http://www.trademotion.com/partlocat...?siteid=214078
http://www.trademotion.com/partlocat...97&catalogid=2
about $120 per side, lowest i found, frsports will only sell you in pairs for 300. for s14
SwiftS14 is offline   Reply With Quote
