Old 05-14-2007, 12:02 AM   #1
Tom Ngan
Tom Ngan's Avatar
Tom Ngan has a spectacular aura aboutTom Ngan has a spectacular aura aboutTom Ngan has a spectacular aura aboutTom Ngan has a spectacular aura aboutTom Ngan has a spectacular aura aboutTom Ngan has a spectacular aura about
Z brake question - stripped - :(
Upon installation of my Z brakes up front on my S14 I realized that one of the inlets on the caliper is stripped.
My conversion lines go in but only partially and the brake fluid still leaks out.
The hole where the brake line goes into the caliper is stripped. Anyone has any recommendations on how to fix this? My friend said I can just retap it and get a bigger fitting, is there any way to retap it and just reinstall the brake line as if it wasn't stripped in the first place?
Also I was unaware that I should use plumbers tape on the brake line, would this be enough to stop the brake fluid from leaking?
Any help would be awesome thanks
Tom Ngan is offline   Reply With Quote
Old 05-14-2007, 12:14 AM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
use thread lock red or blue. works like a charm. put the theard lock liquid around the threads for the conversion lines. to plug that sucker in and wait til it dries up and there you go.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 05-14-2007, 01:44 AM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I would try a tap the same size. See if that works. Also I believe you are talking about teflon tape. The white one is make for water/steam and the yellow one is made for gas/solvent. However, you shouldn't need to use it. Especially for the brakes.
Jung918 is offline   Reply With Quote
Old 05-14-2007, 04:42 AM   #4
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
If its stipped beyond repair it would be easier and cheaper to go ahead and retap it a larger size.
"Home is where the armor is"
nassin31spr is offline   Reply With Quote
Old 05-14-2007, 05:31 AM   #5
sr240dett3
sr240dett3 is making a name for him/her selfsr240dett3 is making a name for him/her self
try to re tap it the same size, and yes you can use Teflon tape on the fitting to the line to the caliper.
My PDM brake lines come with Teflon tap on that fitting.
And just a reminder.. be careful with aluminum (guessing thats what you have) calipers.. they strip easily
S13 - RB25
sr240dett3 is offline   Reply With Quote
Old 05-14-2007, 12:02 PM   #6
cdlong
no! no teflon tape! they're straight cut threads, tape won't help because it's made for tapered threads. the seat is what makes the seal, not the threads.
just clean up the threads the best you can so you can thread the line in. if the remaining threads are strong enough to hold the line with the proper torque, the seat will still seal properly and you'll be fine.
if not, just buy a new caliper. don't ghetto rig something that keeps you from crashing into stuff.
cdlong is offline   Reply With Quote
Old 05-14-2007, 12:49 PM   #7
sr180sx
sr180sx is an unknown quantity at this point
You can still use teflon tape on straight threads, you just need to put enough on that it all goes to the back and creates an o-ring type seal. thats what they do in Europe
sr180sx is offline   Reply With Quote
Old 05-15-2007, 02:31 AM   #8
Tom Ngan
Tom Ngan's Avatar
Hmm.. I like the thread lock idea. But lets hear some other options.
Would thread lock permentally stick the lines to the caliper?
I think its a waste of money to buy another caliper especially if my current one is perfectly fine, freshly rebuilt etc.
Is there anyway to retap it myself? what are the procedures? I called around shops and their going to charge me 100 bucks roughly to retap it....
Old 05-15-2007, 06:27 AM   #9
nassin31spr
Go to your local hardware store. Some wheres that sells tools even Lowe's. They will have tap and die kits. Lows has some by size. Take your 1/8npt fitting with you and most hardware stores will point you int the right direction and the size to go with. You get the kit its a tap, handle, tap lube, drill bit. You take the caliper and clean it off. Put it on a level surface and very carefully drill it out with a high speed drill. Make it as straight as you can. Clean it out, get your tap kit, I use a easy tap lube or oil. Hold the tap firmly and begin threading it into the whole. Try to be aware of the depth and make sure you don't strip it out again. When you are at the depth you want back it out and clean it up and your good to go. I would advice stripping out some old calipers and at least try it once on another caliper before you try it on z32 calipers. Practice makes perfect but its actually really easy. Good luck.
Old 05-15-2007, 08:50 AM   #10
Jung918
Jung918's Avatar
^If he makes the holes bigger he wont be able to use the lines he has now.
Old 05-15-2007, 03:29 PM   #11
Tom Ngan
Tom Ngan's Avatar
I guess would using thread lock be a ridiculous idea?
I don't mind if the line is stuck to the caliper forever, but I don't want it to undo itself or anything as i'm driving.
Old 05-15-2007, 06:05 PM   #12
nassin31spr
He has to order a new fitting to fit the caliper. The stock size is 1/8th npt. he just has to go one size up. These are conversion lines not stock ones.
Old 05-15-2007, 06:17 PM   #13
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Wow I wanted to leave this alone but since there is no logic going on here I am going to interject.
IF YOU HAVE ANY DOUBT AS TO THE INTEGRITY OF YOUR BRAKE SYSTEM DO NOT BAND-AIDE THE PROBLEM!!!
Are you guys retarded? this is his brakes, the things that keep your from running into stuff we're talking about.
Don't use teflon tape or thread loc, thats not what the fitting is designed for. First try a tap with the OEM thread pitch, and if it still leaks, junk it and get a new caliper.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 05-15-2007, 07:47 PM   #14
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
^^^Definitely. C'mon guys, thread lock? Teflon tape? Do it right and re-tap, basically what tknbkthrsdy4anfg stated. The brake system is hydraulic so shit has to fit PERFECTLY. I wouldn't trust any of the other suggestions at all. If you mickey mouse your lines, you'll regret it when you lose all brake pressure and can't stop at a critical moment. Trust me, don't go around it because you want to save a couple of bucks and want your car on the road now.
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 05-15-2007, 08:14 PM   #15
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
word, don't ghetto that shit.
if its fucked just buy a new one fromt he parts store.
O3DigitalBath is offline   Reply With Quote
Old 05-16-2007, 12:59 AM   #16
jspecusa
jspecusa's Avatar
jspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfection
Send a message via AIM to jspecusa
z calipers are cheap by itself, it's only your life so spend what you think it's worth.
I like overkill on brakes, once you had nice brake you can't go any less.
Nissan Japan: "road to happiness has many curves"
Jdmlivin: "Jdm is dead, the yen is crazy"
jspecusa is offline   Reply With Quote
Old 05-16-2007, 06:14 AM   #17
nassin31spr
Tell you the truth I should apologize to you to. It was irresponsible of me to give you the advice to re-tap it. Brakes are one of the most important things on your car and you really shouldn't settle for anything less than perfect. You can re-tap but it is a lot safer to go with new or another caliper. The choice is yours and sorry again.
