"Bee R
Rev Limitter with Mis-firing Action
Use the Bee Racing Rev Limiter to help protect your engine. Instead of causing fuel-cut which can cause stress on the engine, the Rev Limiter cuts the ignition. This action also results in a "mis-firing" simulation. If you have a test pipe on your vehicle, the results would be flames if you load the system enough with fuel. If you still retain your catalytic converters, you will hear a popping sound. The mis-firing control allows you to set the style of mis-firing simulation."
- YES YES YES
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
