Old 05-29-2007, 12:32 PM   #1
mashloh
mashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the roughmashloh is a jewel in the rough
finally got on the dyno! S13 SR with stock T25
Finally got my car dynoed. got in 3 runs with some slight afc adjustments after the first run. Showing just the first and 3rd runs.
was done with a 3rd gear pull.
mods are:
SR redtop, stock T25, mbc set to 14psi, FMIC, Tomei exhaust mani, megan turbo elbow, greddy 3inch downpipe, test pipe, 3inch RSR exmag exahust, megan light weight pulleys, NISMO lightweight flywheel, SAFC, walbro 255lph fuel pump, and some other suspension mods which are irrelevant here.
comments and suggestions welcomed
mashloh is offline   Reply With Quote
Old 05-29-2007, 12:56 PM   #2
Sileighty_85
Sileighty_85's Avatar
Thats it? 230Hp thats alot of money for just 30Hp gain... No disrespect intended just suprised I would have expected a little closer to 250Hp even on a T25. But hey better than an N/A Ka ^_^b
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-29-2007, 01:56 PM   #3
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
230 is a good number stock turbo/injectors too. what im really liking is the tourqe numbers 245 nice!!!
arkive43 is offline   Reply With Quote
Old 05-29-2007, 02:01 PM   #4
MomentumGT
MomentumGT's Avatar
MomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to behold
Sounds about right with those mods but I'm liking the torque a lot.
-Jon
momentumgt.com - "building blocks of speed"
MomentumGT is offline   Reply With Quote
Old 05-29-2007, 02:07 PM   #5
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
torque looks great... i wonder if you would get the same results if you had the megan manifold instead of the tomei....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 05-29-2007, 02:49 PM   #6
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
huh?
30hp gain from what? stock?
you do realize he posted dyno results, not crank results,
so doing basic assumption calculations 230 with 15% drive train loss, he's putting up ~270 crank hp comparing to stock 200
Wei240 is offline   Reply With Quote
Old 05-29-2007, 02:51 PM   #7
Wei240
also realize, to OP, do you have any intake mods, like air filter or anything?
that my increase it a blip...
but those results are good, the max (maf and injectors) with that setup is 250whp, so it's all good
Old 05-29-2007, 02:52 PM   #8
steve shadows
steve shadows's Avatar
it would be interesting to see if you remove the AFC completely and compare the exact same set up to a properly tuned ROM.
It might be a wierd interesting experiment.
Like Me on FaceBook !
Old 05-29-2007, 04:30 PM   #9
mashloh
oh yah, I just remembered that the ECU is a mine's ECU that came with the engine... so who knows if that's making a difference not..
and yes, i do have a generic cone air filter.
Old 05-29-2007, 04:46 PM   #10
Wei240
what you need to do is junk that mine's ecu unless you know someone who can hook it up and retune/reprogram the board, it could be tuned for a setup much different from yours...
or just go to enthalpy to get the ecu tuned so you can also junk the afc, lol
Old 05-29-2007, 04:51 PM   #11
steve shadows
yeah junk it, i had one that was from japan, not tuned for US gas it wrecked my exaust temps and the timing map all wrong for almost anything
Old 05-29-2007, 04:58 PM   #12
91rusty240sx
91rusty240sx's Avatar
91rusty240sx is on a distinguished road
why do 3rd gear runs? 4th gear is direct drive no?
Tony
91rusty240sx is offline   Reply With Quote
Old 05-29-2007, 10:17 PM   #13
mashloh
yah, i plan on going with an enthalpy tune when i upgrade the turbo.. for now though i think i'll be focusing on suspension parts and a paint job...
