Old 05-26-2007, 11:05 PM   #1
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
Help with KA-T setup. Turboing the car soon.
Hi guys, I am about to do my turbo setup and I had a few questions:
Does it matter where I mount my BOV: cold or hot side? It's a blitz DD.
Is there anyone out there with a similar setup that could tell me some safe SAFC II settings so I can drive the car safely before getting it tuned? Basically I would want to know the settings that I would need to make it run rich enough so there is no danger of it leaning out on me. I have the sr injectors in there right now on a stock KA and I just did -27% accross the rpm range at both low and high throttle and the car runs fine.
Are ebay boost controllers ok or should I get brand name? I was thinking of maybe getting one but I'm not sure, I was hoping for around 250hp, is this achievable with this setup at stock boost?
And I also heard you can basically do a home made boost controller, any info on this?
Any help is greatly appreciated, especially any incite into SAFC II settings.
Thanks, Alex.
My setup:
-s14 t28 at stock boost
-Ebay Godspeed FMIC
-Taurus e-fan
-Megan 2.5" catback
-ebay manifold and downpipe
-Walbro 255 pump
-SAFC II
-SR 370cc's
-stock s14 MAF
KAs14slider is offline   Reply With Quote
Old 05-26-2007, 11:25 PM   #2
Irukandji
kat.org
BOV location doesn't matter, but it's easier to recirculate if its on the hotside. You'll eventually want to get a tune, but if you're okay with a ghetto setup then yeah the car will run. If you want to have a ghetto tune, just borrow a friends wideband or just buy one and tune accordingly. Notice the word "ghetto".
Car should run fine.. congrats on getting it running
Old 05-26-2007, 11:40 PM   #3
GSXRJJordan
GSXRJJordan's Avatar
Ugh, so many taboos in that post. First off, yes, go to kat.org and browse for your answers there - note the word 'browse' and not 'post'.
Okay, lets take these in order:
1) BOV doesn't matter, like nismor said, easier if you do hot side.
2) Yes, KAT can give you an idea of some settings, but basically it'll run just like you've got it.
3) Ebay manual boost controllers are ok, they work, but an EBC is much better. If you're going EBC, go brand name.
4) THERE IS NO STOCK BOOST FOR A KA. I hate it when people say "oh it's on stock boost". What you mean to say is, it's on wastegate, or it's on ~7lbs.
5) Don't make a home made boost controller.
Old 05-26-2007, 11:50 PM   #4
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
Check out ka-t.org for SAFC settings and all things KA turbo.
250whp is possible with the t28, but not at stock boost (may need to upgrade your MAF too).
BOV location is a matter of opinion. Most use the hotpipe.
You need to at least retard your base timing a couple of degrees. If you want to turn up the boost, I suggest getting an MSD BTM or ECU tune. Too much timing + boost = broken stuff.
For an affordable, proven boost controller, go here http://www.voodooboost.com/boost_con.../Voodoo_I_MBC/
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 05-26-2007, 11:56 PM   #5
KAs14slider
Ok, thanks for the info. And yes, I meant 7psi, sorry for the confusion. And yeah, I do go on KA-T, I just like to post in multiple forums.
Old 05-27-2007, 12:16 AM   #6
KAs14slider
Any idea on how much to retard the timing? So to retard the timing I would just turn the distributor counter-clockwise?
Old 05-27-2007, 06:33 PM   #7
beetlejuice
Yes, counter-clockwise.
"http://forums.freshalloy.com/showthread.php?t=129132"
jollydwarf.com
Old 05-27-2007, 07:32 PM   #8
Irukandji
More retard = safer
more advance = more power
Just gotta find the right balance. If you run 10psi, it's normal to run around 14 -16 degrees retarded
Old 05-27-2007, 09:16 PM   #9
johngriff
johngriff's Avatar
Plugs and GAP, need a KA person to chime in on the P/N, but NGK-R heatrange 7 or 8's. Gap... uh... no larger than .032!
[email protected]
Old 05-27-2007, 09:21 PM   #10
smokey861
smokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nicesmokey861 is just really nice
buy a chipped ecu. Ive seen too many ka-t mess up on 7psi because of goffey safc settings.
smokey861 is offline   Reply With Quote
Old 05-28-2007, 04:39 PM   #11
KAs14slider
Originally Posted by n1sm0r View Post
More retard = safer
Do I need a timing light? Should I just set the car to normal timing and then move the distributor counter-clockwise?
Old 05-28-2007, 04:41 PM   #12
Irukandji
Yes, get a timing light. Don't guestimate that shit. I'd start at 14 degrees, drive it and see if it knocks (on your safc2). Run premium. Done.
Johngriff is right, don't forget sparkplugs. Just go to an autoparts store and ask for NGK plugs that's one step colder. I'm pretty sure its the 7's.
Old 05-28-2007, 11:22 PM   #13
KAs14slider
Ok, I'll have to hook up the knock wire to my safc II. And right now I am running NGK BKR7's in the car. What is a safe knock reading? Or should it not go over 0?
Old 05-28-2007, 11:29 PM   #14
KAs14slider
Anyone know where you would connect the line that runs from the wastegate to?
Old 05-28-2007, 11:51 PM   #15
beetlejuice
There are two schools of thought on this.
Some connect the wastegate line as close to the compressor outlet as possible, to get the most accurate "compressor" boost reading. Many turbos have a provision for this (threaded hole for a fitting on the compressor).
However, there are others who connect the wastegate line to the intake manifold after the throttle body. This way, you get the most accurate "intake manifold" boost reading. This is the actual amount of pressurized air that is ingested by your combustion chambers.
7psi at the turbo outlet doesn't always mean 7psi in the intake manifold.
It is normal to lose 1psi-2psi worth of pressure drop between the compressor outlet and the intake manifold, especially when using a front mount intercooler.
I would suggest the intake manifold, after the throttle body.
jollydwarf.com
Old 05-28-2007, 11:54 PM   #16
umsports
umsports's Avatar
umsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura aboutumsports has a spectacular aura about
The spark plug you'll want to run is a BKR7E11 and that's an NGK plug. I get them from Advance Auto when I need a set. The gap will be fine at .32 for your boost setting. Are you internally or externally wastegated?
2010 R35 GTR 600whp @21 PSI (E85)
1998 RB26DETT 240SX 810whp@28lbs
umsports is offline   Reply With Quote
Old 05-29-2007, 12:13 AM   #17
eastcoastS14
eastcoastS14's Avatar
I always heard BOV closer to the throttle body for better response
eastcoastS14 is offline   Reply With Quote
Old 05-30-2007, 01:19 AM   #18
KAs14slider
It is internally gated stock wastegate.
Old 05-30-2007, 01:50 AM   #19
that180guy
that180guy is making a name for him/her selfthat180guy is making a name for him/her self
Send a message via AIM to that180guy
fail ben.
honestly, not that many local auto parts guys knows theyre chits.
LP stylez!! bishes Lazy Penguin since teh 04'
Part of the Elite Shasta Speed Stars
RIP......05-09-03....*sniff sniff
the beast nears completion.....
YOU LOOK AND U BUY STUFF !!!!!
that180guy is offline   Reply With Quote
Old 05-30-2007, 02:08 AM   #20
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
For a good starting point retard the timing .5 degress for every lb of boost.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 05-30-2007, 11:21 AM   #21
Irukandji
Originally Posted by that180guy View Post
fail ben.
The Kragen in Concord is pretty knowledgable.. they've help me with a lot of chit. But yeah, I agree somewhat that most the people who work there don't know shit.
where the hell have you been alex
Old 05-30-2007, 11:29 AM   #22
steve shadows
steve shadows's Avatar
Run the largest possible plug gap you can without misfiring.
This will garner the best HP and toruqe as well as power band, throttle response and most importantly gas milage.
Strength of spark is important when it comes to this.
.030 is a good spark plug gap for 15-20 PSI depending on ocatne.
But ive run .030 into 22+ psi ranges. Its all in the tune and supporting mods.
anyways don't mean to confuse you, but there is no one size fits all when it comes to tuning and plugs/gap.
7 range is plenty btw, 8 is overkill.
Like Me on FaceBook !
Old 05-30-2007, 09:47 PM   #23
KAs14slider
What will happen if the plugs are not gapped properly? I think mine are at .30 right now.
Old 05-30-2007, 09:50 PM   #24
KAs14slider
Also, another small question, anyone know what's the best place to run lines for gauges throught the firewall on an s14? I want to install a boost guage and a oil pressure gauge. And any good wrietups on oil pressure gauge installation?
Old 05-30-2007, 10:01 PM   #25
eastcoastS14
pretty simple...if you look in the engine bay youll see rubber grommets in the fire wall....theres some on the passanger side, my guages were run behind the dash and through the grommets, usually if you pull of your glove box and have a friend shine a light through the grommet you can find the hole pretty easy but you may have to cut away some of the material to make the hoses and wires fit through
also be sure to cover the area that will be in contact with the firewall with something so that theres no chance of the metal rubbing through
Old 05-30-2007, 10:26 PM   #26
KAs14slider
Ok, so there is no easy access through the firewall on the driver side? So you had to take your dash apart to do your gauges?
Old 05-30-2007, 11:15 PM   #27
beetlejuice
Gauges...
1) Find a suitable location on your firewall.
2) Drill hole in your firewall.
2) Install rubber grommet in the hole you just drilled.
3) Run lines for gauges through the grommet you just installed in the hole you just drilled.
You do not have to take your dash apart.
For the oil pressure gauge, you can use a oil filter sandwich adapter, which will have provisions to mount your oil pressure sender.
or
You can tee off your stock oil pressure sender.
jollydwarf.com
Old 05-30-2007, 11:23 PM   #28
eastcoastS14
no you dont have to take your dash apart...i just pulled my glove box door off for easier access....You sholdnt have to drill holes either....I ran my battery relocation wires and gauges through exisiting holes in the firewall...just look in the engine bay, youll see them
