wiring from usdm s14 kouki to jdm kouki front
i want my jdm amber turn signals to be on when headlights are on, and blink when i hit turn signal. right now they only blink like turn signal* the way they are designated to be*
although on the usdm bumper the amber on the side of the car is on when the lights are on..i wanted to know if i spliced the wires that were intended for that into the wires for the turn signal, if i would get both functions if not, how can i achieve what i want to do? thanks in advance guys
WTB-NARDI wheel & NRG 2.8 QR |
This is all speculation since i am not near my car to test it with a dmm or anything, but why not splice the jdm turn signal into the usdm bumper light harness.
If you cant do that for whatever reason, then i think it will take a simple circuit to get your desired results. If you went the way you suggested then mabey it wont work because there will always be a signal going to it to keep th light on. So even if the blinker has been turned on it will not blink but remain on. Like i said i have no idea what im really talking about seeing how i cannot test it on my own. and have yet to get down and dirty re-wiring my lights, so take what i say for a grain of rice. im sure someone who has had more practice with the lighting harness will be able to help you out, and shoot holes through my theory. |
#3 | |
did you ever figure out how to wire up those bumper lights because im having the same problem right now and could use some help
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next? |
#4 | ||
![]() Join Date: Jul 2005
#5 | |
![]() Join Date: Feb 2002
RUTH'LESSDET - It would have been better to PM him and see if he went that route. Since I have kouki turn signals, I will tell you what I ended up doing.
I found a junkyard S14 and snipped the two bumper sidemarker sockets and connectors (pigtails). I replaced the USDM front bumper turn signal ones with these and used the existing USDM front bumper sidemarkers for the side lighting of the JDM turn signal. I only went this route because I didn't have the original JDM harness and in my state (VA) there needs to be a bumper sidemarker light. I hope this makes sense. Quote:
Goals are dreams with a deadline. L.H.O.O.Q. |
#6 | |
Thanx for the the help
![]() Quote:
#7 | |
thanx alot for the help
I plan to use my fogs again when I get the brackets eventually
![]() Join Date: Aug 2002
can you actually do that with the s14 turn signals? i tried doing this for my s13 kouki turn signal lights but i found out that you either need a dual filiment bulb/drill a hole and stick another bulb in there and make a custom harness or make some kind of wiring scheme with automotive relays. i tried to learn more about relays on the12volt.com but gave up so i just spliced wires and ran them how they were intended stock (position lights always on/turn signals always off and only blinks when you signal)
don't worry about ppl ethugging you about reviving an old technical threads. i dont know why its a common nowadays for everyone to state 'this thread is over xx amount years old' for EVERY thread revivied including technical threads. we want ppl to search, but everyone is quick to flame every revived old thread and it'll just discourage ppl to use the search function. if it was a fs/wtb thread i would understand the flame but not this. you searched and didnt make another thread to clutter shit up. good job. |
#11 | |
thanx for the help...yeah I'm not worried about some internet thug...plus he's a newbie to the forum anyway. I never b*tch at people whe they r asking for help because actually this was why this forum was created and also why the forum has a search. I looked thru about 6 different thread and none helped but this one was the same problem I was having...
I was searching around on zilvia again and found the connector i need to plug up the lights and make them look as oem as possible.
![]() If you are interested in getting them they are only $6.05 from mynismo.com https://www.mynismo.com/products/?id=5306
