Old 06-04-2007, 07:10 PM   #1
2l84u
2l84u's Avatar
2l84u is an unknown quantity at this point
Clean 91 s13 sr20det
White 91 s13 sr20det
229,000 miles on Body - Approx 46,000 miles on Motor swap
All Parts listed below were purchase new and installed from February 07 till present day.
95% of all parts installed have less than 5k on them!
Have over $11,000 invested with receipts - Asking $6,500 OBO
-This is my daily driver. Selling vehicle because I’m getting married and looking to purchase a house.
Interior:
Coupe dash with working JDM HUD, couple minor cracks in dash
Extra HB dash with 2 hairline cracks (tried to adapt for HUD)
Newer OEM carpet (charcoal)
Celica GT seats (Black)
CD player (MP3, WMA)
Kenwood speakers in all 4 corners
OEM Shift Boot (New)
Exterior:
Borbet 15x7 +35 aluminum five spoke rims wrapped in NEW Yokohama directional tires (H rated )
JDM Silvia wing
Sun Roof (No leaks)
Engine:
JDM SR20DET Full Engine Swap (Swapped by Eugene)
Head/block was milled by Abacus Racing. (Cylinder walls, piston tops and valves looked great)
ARP Head Studs (Installed by Abacus Racing)
Cometic 1.01 Metal Head Gasket (Installed by Abacus Racing)
NGK Iridium Spark Plugs Heat 6
Greddy Rocker Arm Stoppers
Hayden Electric Fan: 16ā€ 1500 CFM
KOYO Aluminum Radiator with Greddy Cap 18.5 psi
Nismo Thermostat
SAMCO Silicone Radiator Hoses
Hybrid Development Intercooler Kit
Enjuku racing Hot Pipe with HKS BOV Flange
HKS SSQV Blow-off Value
Walbro High Pressure 255ltr/hr Fuel Pump
New 300zx Fuel Filter
Rebuilt T-25
Power Steering Pump Replaced
New Water Pump
Turbonetic T-Clamps
Transmission:
Manual 5 Speed
Agency Power Stainless Clutch Line
B&M Short Shifter
Fidanza Lightweight Flywheel
SPEC Stage 3 Clutch
New Slave Cylinder
Engine Accessories/ Maintenance:
CUSCO Front OS Strut Bar
Odessey Lightweight Race Battery (11 Lbs)
Megan Racing Brake Cylinder Heat Shield
Blitz LM Air Filter
Peak Performance Magnetic Oil Drain Plug
Mr Gasket Exhaust Manifold (Copper)
OEM Turbo Inlet Gasket
OEM Turbo Outlet Gasket
OEM Value Cover Gasket
Complete Belt Set
Nismo Motor mounts and Transmission Mount
New Heater Hoses
Peak Performance Thermal Intake Gasket
Circuit Sport Oil Catch Can
New Fuel Lines and vacuum lines
Pipe Couplers were all replaced
Changed Transmission fluid to Full Synthetic
Running Mobile 1 10w-30 Full Synthetic
Suspension:
KYB AGX Adjustable Struts
TEIN S Tech Lowering Springs
Power Brace Weld In
New Outer/Inner Tie Rods (Installed by All Aspect Motors)
New Steering rack (Installed by All Aspect Motors)
Exhaust:
Circuit Sport O2 Elimination Down pipe
Megan Racing Test Pipe
Circuit Sport 3ā€ DT Cat Back Exhaust
Circuit Sport Exhaust Hanger Bushings
Ichiba Turbo Manifold (identical to Tomei Expreme)
OEM Fatty o2 Sensor
Electronics:
Greddy Profec Spec B-II Electronic Boost Controller
Apex-I Auto Turbo Timer- Silver with harness
Parts given with sale:
Z32 4 piston Aluminum 30mm front brakes with Endless Racing Pads
Nismo 60mm Extended studs
H4 Conversion Lights
Contact Information:
James
[email protected]
Cell- 757-971-1495
2l84u is offline   Reply With Quote
Old 06-06-2007, 02:39 PM   #2
2l84u
2l84u's Avatar
Bump with price drop
Old 06-06-2007, 03:02 PM   #3
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
trade for this?
http://www.zilvia.net/f/showthread.php?t=145757
Full-Lock is offline   Reply With Quote
Old 06-09-2007, 01:25 PM   #4
2l84u
2l84u's Avatar
Daily bump..TTT
Old 06-09-2007, 07:25 PM   #5
timek1m
timek1m is an unknown quantity at this point
hey where is the car located? willing lower the price down to the 5K area?
timek1m is offline   Reply With Quote
Old 06-11-2007, 07:53 PM   #6
2l84u
2l84u's Avatar
Pending sale
Pending sale for 6k
Old 06-27-2007, 09:05 AM   #7
2l84u
2l84u's Avatar
Sold!!
Car is sold please delete
