Old 07-05-2007, 01:33 AM   #1
2.240s
2.240s will become famous soon enough2.240s will become famous soon enough2.240s will become famous soon enough2.240s will become famous soon enough2.240s will become famous soon enough
megan pulleys/pwr steering ??
Anybody notice a difference in steering with megan/greddy light weight pulleys ? Does the power steering feel any lighter ??
2.240s is offline   Reply With Quote
Old 07-05-2007, 01:44 AM   #2
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
no just for looks. just buy them if you have a bent or cracked pulley. they just way less. only thing that would ever change on the acc pulleys is the water pump pulley if its 5% smaller. just spins the water pump faster. but they do look good. i got some $99 ones off some jdmsomething sight.
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 07-05-2007, 01:53 AM   #3
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Hello you will not see any huge gains. The aluminum pulleys weigh less ,wich will help in reducincing paracitic losses(ie) the engine will not have to work as hard to produce the same revs. IMHO combine it with a aluminum crank underdrive pulley & its a worthy upgrade!!!! LATE
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 07-05-2007, 01:56 AM   #4
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
Like stated above, no real gains but mostly for eye candy. An engine looks completely different with pulleys on. Makes it look more "built" i guess.
Vision Garage is offline   Reply With Quote
Old 07-05-2007, 11:00 AM   #5
2.240s
Right on Thanks for the input.
