Old 07-10-2007, 12:35 AM   #1
uthemofo
uthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to alluthemofo is a name known to all
Send a message via AIM to uthemofo
sr with koyo overheating on freeway??? wtf??? help please!!!
Ok so i just put in a koyo that i got used with some dule flex-a-lite fans, yes i now know that they are crap but i got the fans and the koyo for $200 so no complaints. So after one track day i decided to take those fans out and get my self a tarus fan, I installed the fan and actually made my self a piece of aluminum that covers the whole rad. this fan works way way better. i have it wired to a auto temp sensor that come on between 180 and 220 and i can adjust it, i have it set at 170 and it runs cool all day long. UNTILL i got on the freeway, i was cruzin on the freeway at like 65 or 70 and then it started to climb in temp... im like wtf why would it do that especially since its a nice cool night on the freeway.
it did this all the way home, i would stop let it cool then it would heat back up again, stop cool and same thing.
my question is WHY why would it do this? maby the rad is partly clogged??? maby my thermostat is being wack? stock one by the way
i honestly dont know
please help me
thanks
matt
My Feedback
uthemofo is offline   Reply With Quote
Old 07-10-2007, 12:47 AM   #2
ixfxi
Guest
Posts: n/a
i have those fans - i like them, regardless of what people say.
anyway, check to make sure you dont have air in your system.
Old 07-10-2007, 12:52 AM   #3
homegaragespl
homegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to beholdhomegaragespl is a splendid one to behold
check these, fluid levels, belt tension, maybe your fan shroud (oem is the cheapest and best), and of course water pump and thermo stat....in that order..
Buddy club driver side rails for sale $130 obo
homegaragespl is offline   Reply With Quote
Old 07-10-2007, 12:56 AM   #4
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
he has a custom shroud already made for the taurus fans. It could be water pump failed at track and you didnt know. or thermo failure. I woudl say do was homegarage said.
Vision Garage is offline   Reply With Quote
Old 07-10-2007, 12:57 AM   #5
uthemofo
yea all the fluids are perfect belt tension as well, i'm running tarus fan so thats good, my water pump is beginning to leak from the weep hole (pin hole) im guessing thats it? maby as well as the thermostat?
My Feedback
Old 07-10-2007, 02:22 AM   #6
Vision Garage
Okay if the weep hole is leaking that means your waterpump is out or going out. Replace it and you are good to go. Part should be less than 50 for KA. Not so sure on SR.
Old 07-11-2007, 04:58 AM   #7
uthemofo
yea its a little more than that for a sr because i can go down to local auto parts store and pick it up...but through my sponcer VEX MOTOR SPORTS it will be a fair price.
hehe totally promoting their name by doing that but yea thanks guys your replies were great.
thanks
matt
My Feedback
Old 07-11-2007, 05:13 AM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If you have to change your water pump, might as well change your thermostat. Go to Kragens/Pepboys/auto zone and have them match you a colder thermostat. Itll work just as well as the nismo thermostat but cost less than $20. They just gotta cross reference the stock sr thermostat's part number and they should be able to give you something thats colder.
CLICK HERE!!!
Old 07-11-2007, 05:32 AM   #9
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Might as well replace your thermostat while your at it. Also did you bleed all the air from the system?
blu808 is offline   Reply With Quote
