Old 08-10-2007, 12:02 AM   #1
Enomshekiaah2
Enomshekiaah2 is making his/her stupidity well-knownEnomshekiaah2 is making his/her stupidity well-knownEnomshekiaah2 is making his/her stupidity well-knownEnomshekiaah2 is making his/her stupidity well-knownEnomshekiaah2 is making his/her stupidity well-known
KA MY 240sx is eating soo much gas!!
sry i posed this in the tech talk forum more appropriate im sry but keep on posting need alot of advice and willing to learn from wise 240sx peoples
Enomshekiaah2 is offline   Reply With Quote
Old 08-10-2007, 12:23 AM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
did you check ur spark plugs?
was your maf even bad in the first place?
did you replace your air filter, sounds like you have a miss
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 08-10-2007, 12:28 AM   #3
Enomshekiaah2
umm i bought spark plugs but i didnt need to change it..i have a injen intake and when i bought the car which was 3-4 weeks ago it was just like this rev limit and mis fire when idling *like a popping sound* but i should get a tune up as well tho
Old 08-10-2007, 12:46 AM   #4
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
my S13 eats gas too, but yea look into getting a tune up, plugs,wires,distributor cap,rotor also get your timing checked.
projekt_s13 is offline   Reply With Quote
Old 08-10-2007, 01:13 AM   #5
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
Your timing is probably retarded.
And your 02 sensor is most likely bad.
Those 2 things will help a lot.
Then do a general tune-up.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 08-10-2007, 01:18 AM   #6
Enomshekiaah2
Thanks guys im on it. Ill check the timing and the o2 sensor then the tune up. Thanks alot for the help
Old 08-10-2007, 01:38 AM   #7
bo2o
bo2o's Avatar
fuel pump also
2nd on that timing
^^^click^^^
Old 08-10-2007, 02:19 AM   #8
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
how about the MAF, wouldnt a faulty MAF cause it to run on close loop running rich.
Ragnarok043 is offline   Reply With Quote
Old 08-10-2007, 02:39 AM   #9
projekt_s13
^^^^^^^^^^^^ he replaced it already.
Old 08-10-2007, 04:28 AM   #10
kleenS14
kleenS14's Avatar
kleenS14 is an unknown quantity at this point
+1 on O2 sensor. they will ruin your mpg. The back-up tables are really rich from what I know.
kleenS14 is offline   Reply With Quote
Old 08-10-2007, 07:49 AM   #11
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Yea they are.
I haven't had a funcional o2/ no exhaust leaks in a long time, lol.
car runs rich as shit.
check your o2.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 08-10-2007, 12:10 PM   #12
Enomshekiaah2
Ok thank you everybody ill look on all of the things that you told me
Old 08-10-2007, 12:18 PM   #13
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Did you try checking your ECU for codes yet?
That'd be my first step in problem diagnosis.
There are a lot of things that can cause your car to run rich and/or get bad gas mileage.
Check your codes first and then go from there.
HalveBlue is offline   Reply With Quote
Old 08-11-2007, 12:00 AM   #14
Enomshekiaah2
hmm ecu codes i juss bought the 240 so im kinda new where is the ecu and the right coding how do i know?
Old 08-13-2007, 01:49 PM   #15
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
ECU is located at the foot of your passenger interior, kick panel, held in via 3 screws iirc. for codes and descriptions search.
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 08-13-2007, 01:54 PM   #16
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
might wanna check the evap system. i'm getting pretty bad gas milege and my check engine light is on.....=(
916S14 is offline   Reply With Quote
Old 08-13-2007, 01:59 PM   #17
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
Ha you might wanna do a major tune-up. If you kept your car in shape it wouldn't have such a bad diet on gas. Prolly all choked up on carbon and dirt.
kick rocks.
Buffalo Daughter is offline   Reply With Quote
Old 08-13-2007, 02:06 PM   #18
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Old 08-13-2007, 05:41 PM   #19
Bizzytony
Bizzytony is on the path to ruinBizzytony is on the path to ruin
like they said do the small stuff, plugs, oil, fuel filter. But what works best for me is use a Lucas Oil Brand injector cleaner, it works wonders. I know some people say it dont do shit but i use it every 1500miles i get 27.7 mpg, and my bro used it in his v8 lexus ls400 he went from 200 miles per tank to 300, no shit, for 3 bucks cant go wrong
http://www.lucasoil.com/products/dis...tid=2&loc=show
Bizzytony is offline   Reply With Quote
Old 08-13-2007, 06:01 PM   #20
Jsellers
Jsellers's Avatar
Jsellers is an unknown quantity at this point
Do a full tune up and also try doing about 70mph on the highway. I had a MK3 Supra before my 240 and i was complaining about bad gas mileage. I started driving slower and I immediately saw a difference.
Good Luck!!!! =D
Don't be a Ricer.
Jsellers is offline   Reply With Quote
Old 08-13-2007, 06:32 PM   #21
longdy
longdy's Avatar
longdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud of
Send a message via AIM to longdy
lol i think everyone here is having some kind of issue with fuel! lol
Summer project: Rx-7 Vert
longdy is offline   Reply With Quote
Old 08-13-2007, 10:33 PM   #22
Enomshekiaah2
thx so what i knwo is chek timing o2 and tune up oil been changed before bought it so i dont think its that but i will prob do everything of the following thx guys n e other this is shud do juss tell me thanks peoples much appreciated
Old 08-15-2007, 10:30 AM   #23
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
If you gotta clean your maf check with an auto parts store such as advance uato parts for this stuff called crm mass air flow sensor cleaner. Comes in an aerosol can, suppose to not damage anything
s13pignose is offline   Reply With Quote
Old 08-15-2007, 10:36 AM   #24
kriptix
kriptix's Avatar
kriptix will become famous soon enoughkriptix will become famous soon enoughkriptix will become famous soon enoughkriptix will become famous soon enoughkriptix will become famous soon enough
Do a tune-up.
Check your timing.
Replace your O2 sensor.
Check for exhaust leaks.
Check your coolant temp sensor, warm up your car and wiggle the connector see if it makes your idle change. If it does get a new sensor and get a new connector.
kriptix is offline   Reply With Quote
